Posted: Wed Aug 01, 2012 6:22 am Post subject: |
Got my eye on it
even though I've already got a spare set of body work  _________________ SB6 mk1 (project mega light, big bore)
Posted: Wed Aug 01, 2012 7:07 am Post subject: |
| Did you catch my comment on Bimota Rear Disc Oily? |
Posted: Wed Aug 01, 2012 7:10 am Post subject: |
| 2bims wrote: |
Yes.......and answered it a few comments back  _________________ SB6 mk1 (project mega light, big bore)
Posted: Wed Aug 01, 2012 9:52 pm Post subject: |
Pictures of the ear disc matey, both sides.
Posted: Thu Aug 02, 2012 9:14 am Post subject: |
Exhaust and swinger back from the welders.....
This is only the second, that I know of (sure there must be others) SB6 with proper paddock stand bobbins and I also did the first ..........
...no more messing about when I want the back wheel out .......
...The new Dymag is a real tight fit being 10mm wider than the oscom but I'm sure that if it thinks it needs more room we can get the grinder out  _________________ SB6 mk1 (project mega light, big bore)
Posted: Thu Aug 02, 2012 10:27 am Post subject: |
| Rear disc is in the post this moning for you, so maybe tomorrow?? |
Posted: Thu Aug 02, 2012 1:24 pm Post subject: |
| oily wrote: |
...The new Dymag is a real tight fit being 10mm wider than the oscom but I'm sure that if it thinks it needs more room we can get the grinder out  |
Hopefully the tyre won't affect the chain run _________________ Don't read everything you believe |
SiBag
Posted: Thu Aug 02, 2012 1:40 pm Post subject: |
| Evilchicken0 wrote: |
| oily wrote: |
Hopefully the tyre won't affect the chain run |
I would think they would not make the slightest difference as the chain is in board of the swinger. _________________ Si...
Posted: Thu Aug 02, 2012 1:46 pm Post subject: |
Dymags drawings for the machining of these wheels is identical for both the Mk1 and Mk11 SB6 so there will be NO problem with the chain run and I suspect the swing-arm/tyre interface can be adjusted/tweaked with different makes/profile of tyre as required
Posted: Thu Aug 02, 2012 1:47 pm Post subject: |
| 2bims wrote: |
Despite what the others say about you, I think your wonderful 2bims  _________________ SB6 mk1 (project mega light, big bore)
Posted: Thu Aug 02, 2012 2:27 pm Post subject: |
| oily wrote: |
| 2bims wrote: |
Despite what the others say about you, I think your wonderful 2bims  |
Didn't know your name was "the Others"  |
Posted: Thu Aug 02, 2012 4:33 pm Post subject: |
Yeah it will probably be fine, mine has about 10mm tollerance, and a wider wheel will flatten the profile.
As long as you don't need to space the sprokets you'll be fine ... because we know what happens when you have to take the sprocket off don't we children  _________________ Don't read everything you believe |
The Others
Posted: Fri Aug 03, 2012 12:03 am Post subject: |
| 2bims wrote: |
| oily wrote: |
| 2bims wrote: |
Oi, You taking the mick?
Posted: Fri Aug 03, 2012 1:58 pm Post subject: |
Didn't know he was called mick ? _________________ Don't read everything you believe |
Posted: Wed Aug 08, 2012 10:26 am Post subject: |
Woo hoo......arrived this morning, almost the last piece of the big bore jig saw....1147cc cometic head gasket .........
...just gota slot the cam sprockets now and I think we're ready to start
