And So It Begins...........Again (SB6)
Goto page Previous  1, 2, 3 ... 5, 6, 7 ... 14, 15, 16  Next
PostPosted: Wed Aug 01, 2012 6:22 am    Post subject: Reply with quote
Desmo_Demon wrote:
oily wrote:
...At the top of the thread I mentioned that the bodywork was probably the last thing to see any TLC but that's all I've touched so far.
Today I spent about eight hours with fibreglass and filler...
If you don't like the way that bodywork is coming along, buy this one and start all over....
http://www.ebay.de/itm/BIMOTA-SB6-Bj-1994-1996-Vollverkleidung-rot-weis-carbon-unfallbeschadigt-/170887225067?pt=Motorrad_Kraftradteile&hash=item27c9ac1eeb
Got my eye on it Wink
even though I've already got a spare set of body work Shocked
PostPosted: Wed Aug 01, 2012 7:07 am    Post subject: Reply with quote
Did you catch my comment on Bimota Rear Disc Oily?
PostPosted: Wed Aug 01, 2012 7:10 am    Post subject: Reply with quote
Yes.......and answered it a few comments back Wink
PostPosted: Wed Aug 01, 2012 9:52 pm    Post subject: Reply with quote
Pictures of the ear disc matey, both sides.
PostPosted: Thu Aug 02, 2012 9:14 am    Post subject: Reply with quote
Exhaust and swinger back from the welders.....
This is only the second, that I know of (sure there must be others) SB6 with proper paddock stand bobbins and I also did the first Wink ..........
...no more messing about when I want the back wheel out Laughing .......
...The new Dymag is a real tight fit being 10mm wider than the oscom but I'm sure that if it thinks it needs more room we can get the grinder out Laughing
PostPosted: Thu Aug 02, 2012 10:27 am    Post subject: Reply with quote
Rear disc is in the post this moning for you, so maybe tomorrow??
PostPosted: Thu Aug 02, 2012 1:24 pm    Post subject: Reply with quote
Hopefully the tyre won't affect the chain run
SiBag
PostPosted: Thu Aug 02, 2012 1:40 pm    Post subject: Reply with quote
I would think they would not make the slightest difference as the chain is in board of the swinger.
Si...
PostPosted: Thu Aug 02, 2012 1:46 pm    Post subject: Reply with quote
Dymags drawings for the machining of these wheels is identical for both the Mk1 and Mk11 SB6 so there will be NO problem with the chain run and I suspect the swing-arm/tyre interface can be adjusted/tweaked with different makes/profile of tyre as required
Wink
PostPosted: Thu Aug 02, 2012 1:47 pm    Post subject: Reply with quote
Despite what the others say about you, I think your wonderful 2bims Laughing
PostPosted: Thu Aug 02, 2012 2:27 pm    Post subject: Reply with quote
Didn't know your name was "the Others" Laughing
PostPosted: Thu Aug 02, 2012 4:33 pm    Post subject: Reply with quote
Yeah it will probably be fine, mine has about 10mm tollerance, and a wider wheel will flatten the profile.
As long as you don't need to space the sprokets you'll be fine ... because we know what happens when you have to take the sprocket off don't we children Very Happy
The Others
PostPosted: Fri Aug 03, 2012 12:03 am    Post subject: Reply with quote
Oi, You taking the mick?
Laughing
PostPosted: Fri Aug 03, 2012 1:58 pm    Post subject: Reply with quote
Didn't know he was called mick ?
PostPosted: Wed Aug 08, 2012 10:26 am    Post subject: Reply with quote
Woo hoo......arrived this morning, almost the last piece of the big bore jig saw....1147cc cometic head gasket Wink .........
...just gota slot the cam sprockets now and I think we're ready to start
Laughing
Page 6 of 16
