		| Author | Message |
		| mm500
				|  Posted: Mon Jun 19, 2017 9:43 am    Post subject: Anybody going for the Pro Map injection |   |
				| http://www.promap-europe.com/PROJETS/006_BIMOTA500%20VDUE.html
 Full kit : EUR 5580 inc vat
 - Ecu.
- Dashboard.
- Electronic power supply unit.
- Throttle body machined for integration of 4 injectors. - Two specific Injectors for low load.
- Two specific Injectors for full load.
- Speed wheel sensor and its bracket
- Fuel pressure sensor.
- Shifter sensor.
- Engine wiring harness.
- Lighting wiring harness.
 Low kost kit: EUR 2485 inv vat
 Strength
 - Better engine response by improvement of the fuel flow with 1 specific injector by cylinder.
 - Fully compatible with the original wiring harness and original sensors.
 Weakness
 - Uses the original Dash Board and wiring harness whose defects are retained. - No suitable for race track because drivability not improved at high rpm.
- No suitable for a tuned engine.
 Content :
 - Ecu
- Throttle body machined for integration of 2 injectors. - Two specific injectors
		| Back to top |  |
		| who
				|  Posted: Mon Jun 19, 2017 10:04 am    Post subject: |   |
				| Sounds like a bargin...  |  |
		| Back to top |  |
		| mm500
				|  Posted: Mon Jun 19, 2017 10:07 am    Post subject: |   |
				| I may have done it for EUR1500...  |  |
		| Back to top |  |
