mm500
Posted: Mon Jun 19, 2017 9:43 am Post subject: Anybody going for the Pro Map injection |
http://www.promap-europe.com/PROJETS/006_BIMOTA500%20VDUE.html
Full kit : EUR 5580 inc vat
- Ecu.
- Dashboard.
- Electronic power supply unit.
- Throttle body machined for integration of 4 injectors. - Two specific Injectors for low load.
- Two specific Injectors for full load.
- Speed wheel sensor and its bracket
- Fuel pressure sensor.
- Shifter sensor.
- Engine wiring harness.
- Lighting wiring harness.
Low kost kit: EUR 2485 inv vat
Strength
- Better engine response by improvement of the fuel flow with 1 specific injector by cylinder.
- Fully compatible with the original wiring harness and original sensors.
Weakness
- Uses the original Dash Board and wiring harness whose defects are retained. - No suitable for race track because drivability not improved at high rpm.
- No suitable for a tuned engine.
Content :
- Ecu
- Throttle body machined for integration of 2 injectors. - Two specific injectors
Posted: Mon Jun 19, 2017 10:04 am Post subject: |
Sounds like a bargin...  |
mm500
Posted: Mon Jun 19, 2017 10:07 am Post subject: |
I may have done it for EUR1500...  |
