pascal07
Posted: Wed Oct 02, 2024 7:58 am Post subject: power commander |
| Hello everyone, has anyone put a power commander or other box on a DB5 ecu Pegaso? Thanks |
hindsight
Joined: 13 Feb 2010 Posts: 131 Location: Central Scotland
Posted: Thu Oct 03, 2024 8:26 am Post subject: |
No, but I put one on a DB2SR (briefly, before I swapped the ECU entirely).
I haven't checked the DB5 setup, but would imagine it to be fairly similar. Two things to watch out for:
1) The wiring for the injectors were reversed from what the PC was expecting - swapping the two pins in the injector connectors on the bikes' loom fixed that.
2) On the DB2SR, the PC was counting revs from the injector pulses, and the OEM was spitting two squirts per revolution. This gave the PC a higher RPM. Usefully Dynojet had a firmware patch for that and I could fix it with simply flashing the PC-V.
I suspect neither of these things might be a problem for the DB5, but worth mentioning.
Dynojet support were excellent.
Regards,
Mike |
hindsight
Duplicate post
hindsight
| Duplicate post |
Quackers
Posted: Thu Oct 03, 2024 4:33 pm Post subject: |
| I put a Power Commander 3 on a DB6 with a Pegaso ECU about 18 months ago. I'm glad I did too. |
pascal07
Posted: Sun Oct 06, 2024 5:08 pm Post subject: |
| hindsight wrote: |
| Duplicate post |
Thanks Mike for these informations |
pascal07
Posted: Sun Oct 06, 2024 5:09 pm Post subject: |
| hindsight wrote: |
Regards,
Mike |
pascal07
Posted: Sun Oct 06, 2024 5:10 pm Post subject: |
| hindsight wrote: |
Regards,
Mike |
pascal07
Posted: Sun Oct 06, 2024 5:16 pm Post subject: |
| Quackers wrote: |
Hi, thanks for this information, it's PC III Triumph 955 or an other?
Thank you |
Quackers
Posted: Mon Oct 07, 2024 2:35 pm Post subject: |
Two PC3's were recommended by DynoJet when I spoke to them a couple of years ago: 717-411 (for a Monster 1000DS) or 711-411 (for a Ducati 998).
They're both quite scarce now & it took some hunting to find one - I eventually tracked down & fitted a 711-411. Note that the wiring to the injectors is reversed (Hindsight found the same thing).
Good luck  |
pascal07
Posted: Thu Oct 10, 2024 2:39 pm Post subject: |
| thank a lot, if i don't find i'll take a jet prime db5 |
Quackers
Posted: Sun Oct 13, 2024 12:37 pm Post subject: |
No problem Pascal .
You're right about other options - JetPrime being one. There appear to be some other DynoJet clones too - ie MAGNUM Dyno-Boost Motorcycle Performance Chip & the DM Pro Bimota DB5 DB5R S DB6 R Power Module Programmable Control Unit (to name but two. I've seen others).
I've no experience with any of them, other than the PC3. If you fit anything other than a PC3 it would be good to know which one you chose (& why), how easy it was to fit & tune, & how the bike rides.
Good luck  |
pascal07
Posted: Fri Oct 18, 2024 11:01 am Post subject: |
| I'l order the jetprime and will make a comment about. I hope to correct my fuel richness. |
pascal07
Posted: Fri Nov 29, 2024 4:26 pm Post subject: |
hi, Jet prime db 5 received and installed with map jet prime, good improvement, still to be refined!  |
Quackers
Posted: Wed Dec 04, 2024 11:24 am Post subject: |
| That's gr8 news Pascal. Is it easier to start from cold too? |
