power commander
pascal07
PostPosted: Wed Oct 02, 2024 7:58 am    Post subject: power commander Reply with quote
Hello everyone, has anyone put a power commander or other box on a DB5 ecu Pegaso? Thanks
hindsight
PostPosted: Thu Oct 03, 2024 8:26 am    Post subject: Reply with quote
No, but I put one on a DB2SR (briefly, before I swapped the ECU entirely).
I haven't checked the DB5 setup, but would imagine it to be fairly similar. Two things to watch out for:
1) The wiring for the injectors were reversed from what the PC was expecting - swapping the two pins in the injector connectors on the bikes' loom fixed that.
2) On the DB2SR, the PC was counting revs from the injector pulses, and the OEM was spitting two squirts per revolution. This gave the PC a higher RPM. Usefully Dynojet had a firmware patch for that and I could fix it with simply flashing the PC-V.
I suspect neither of these things might be a problem for the DB5, but worth mentioning.
Dynojet support were excellent.
Regards,
Mike
hindsight
Duplicate post
hindsight
Duplicate post
Quackers
PostPosted: Thu Oct 03, 2024 4:33 pm    Post subject: Reply with quote
I put a Power Commander 3 on a DB6 with a Pegaso ECU about 18 months ago. I'm glad I did too.
pascal07
PostPosted: Sun Oct 06, 2024 5:08 pm    Post subject: Reply with quote
hindsight wrote:
Duplicate post
Thanks Mike for these informations
pascal07
PostPosted: Sun Oct 06, 2024 5:09 pm    Post subject: Reply with quote
Regards,
Mike
pascal07
PostPosted: Sun Oct 06, 2024 5:10 pm    Post subject: Reply with quote
Regards,
Mike
pascal07
PostPosted: Sun Oct 06, 2024 5:16 pm    Post subject: Reply with quote
Hi, thanks for this information, it's PC III Triumph 955 or an other?
Thank you
Quackers
PostPosted: Mon Oct 07, 2024 2:35 pm    Post subject: Reply with quote
Two PC3's were recommended by DynoJet when I spoke to them a couple of years ago: 717-411 (for a Monster 1000DS) or 711-411 (for a Ducati 998).
They're both quite scarce now & it took some hunting to find one - I eventually tracked down & fitted a 711-411. Note that the wiring to the injectors is reversed (Hindsight found the same thing).
Good luck Smile
pascal07
PostPosted: Thu Oct 10, 2024 2:39 pm    Post subject: Reply with quote
thank a lot, if i don't find i'll take a jet prime db5
Quackers
PostPosted: Sun Oct 13, 2024 12:37 pm    Post subject: Reply with quote
No problem Pascal Cool .
You're right about other options - JetPrime being one. There appear to be some other DynoJet clones too - ie MAGNUM Dyno-Boost Motorcycle Performance Chip & the DM Pro Bimota DB5 DB5R S DB6 R Power Module Programmable Control Unit (to name but two. I've seen others).
I've no experience with any of them, other than the PC3. If you fit anything other than a PC3 it would be good to know which one you chose (& why), how easy it was to fit & tune, & how the bike rides.
Good luck Very Happy
pascal07
PostPosted: Fri Oct 18, 2024 11:01 am    Post subject: Reply with quote
I'l order the jetprime and will make a comment about. I hope to correct my fuel richness.
pascal07
PostPosted: Fri Nov 29, 2024 4:26 pm    Post subject: Reply with quote
hi, Jet prime db 5 received and installed with map jet prime, good improvement, still to be refined! Razz
Quackers
PostPosted: Wed Dec 04, 2024 11:24 am    Post subject: Reply with quote
That's gr8 news Pascal. Is it easier to start from cold too?
