Posted: Fri Apr 17, 2015 8:27 pm Post subject: Oil temperature gauge DB5R |
I found that I needed an oil temperature gauge on the DB5R. Only because I just want to know what the oil temp is.
At the pictures you can see how I did it.
I made a carbon bracket.
The location where I have placed the sensor.
Works perfectly..
 _________________ vince
Posted: Sat Apr 18, 2015 3:49 pm Post subject: |
| Very neat job, looks excellent! |
Posted: Sat Apr 18, 2015 6:03 pm Post subject: |
Does it tell the time Vince also? As your clock says it was 12 mins past midnight?
Looks very neat though I have to say....is the chrome toggle switch below so that its not permanently "on" wired to a live somewhere?
Does the kit come with the thermistor brass resistor thats plugged into the gauze oil filter sump?
And lastly...like thats not enough questions already...does it do anything else?? |
Posted: Sun Apr 19, 2015 7:58 am Post subject: |
| 2bims wrote: |
Hi Steve, You have eye for details.
The time was a bit off, I had disconnected the battery for the winter.
The toggle switch is for the headlight. That way I can switch the light off when I start the bike. Normally when I push the starter button the headlight is immediately on, and because it isn’t a bike that will start easy so I think all the power from the battery should go to the starter.
Since I have the switch and a new lithium battery I don’t have any starting problems.
The kit is with the brass thermistor. Only the plug I adapted so that the thermistor is threaded into the plug.
Answer to Your last question, No …… But …. It’s possible to have a second thermistor so you can switch between them. _________________ vince
Posted: Sun Apr 19, 2015 11:49 am Post subject: |
Cheers Vince.....are you getting to use the DB5R much then.....? Is there a favourite developing between the 2 Bims?
The later Db5 and Db6 models all use Koso clocks that has an Oil temperature gauge...albeit in bars rather than actual degrees.....Also when the key is switched on the small sidelight bulb on the front is the only one that comes on now initially prior to starting, causing less of a draw...only when the engine is running does the main headlight and rear tail light bulb come on...so evidently Bimota thought it was a problem and sorted it....nice of them..  |
Posted: Sun Apr 19, 2015 10:23 pm Post subject: |
Great job Vince! Have you done some tests already? I'm interested about the top temperatures... Which oil do you use? _________________ Bimota DB7, Bimota DB5 Mille, Ducati 916, Ducati M900, Benelli Tornado Tre |
spidermaan
Posted: Mon Apr 20, 2015 8:23 am Post subject: |
Hi Vince, I can't from work see your picture, so I don't know if you did the same solution, but I bought this from luis.de
You can see the temperature during ride
 _________________ http://bcomebimota.blogspot.it/ |
Posted: Tue Apr 21, 2015 7:17 am Post subject: |
| spidermaan wrote: |
Hi Spidermaan, It’s not the same solution but yours it’s definitely easier to install.  _________________ vince
Posted: Tue Apr 21, 2015 7:20 am Post subject: |
| CNC wrote: |
| Great job Vince! Have you done some tests already? I'm interested about the top temperatures... Which oil do you use? |
Thanks.
I have taken her for a few short rides. The temperature of the oil was at max 95 ͦC (city traffic), only the ambient temperature was not very high (max 17 ͦC from memory).
I'll keep you updated (If you remind me).
I use 10W40 semi synthetic . _________________ vince
Posted: Tue Apr 21, 2015 7:25 am Post subject: |
| 2bims wrote: |
Not enough, but that is for all my motorbikes ….. not enough time.
I do not really have a favourite. Depends on where I'm going to ride and with who.
If I’m going to ride more geographic flat roads an high speed I prefer the SB6.
If I’m going to ride in the Eifel (Germany) hills an cornering I definitely prefer the DB5R.
I am privileged that I can choose…  _________________ vince
Posted: Wed Apr 22, 2015 7:10 pm Post subject: |
| Vince186 wrote: |
I use 10W40 semi synthetic . |
Vince thanks for info! _________________ Bimota DB7, Bimota DB5 Mille, Ducati 916, Ducati M900, Benelli Tornado Tre |
