Kojay
Joined: 03 May 2008 Posts: 21 Location: Bonnie Scotland
Posted: Sat May 17, 2008 6:08 pm Post subject: Suspension settings |
HI Guys, Does anyone have the info on the standard suspension settings for a SB6R. The guy that had the bike before me has "tweaked" it to the point that it needs a billiard table smooth surface to track a straight line through the bends.
cheers Kojay |
Posted: Sat May 17, 2008 9:52 pm Post subject: |
Yep, I've got the factory settings.
Rear spring preload is 151mm
Rear shock reservoir knob is 12th click out from fully screwed in
Front fork adjustment
Adjusters on top of fork legs are 5th click out from fully screwed in (30 poss clicks)
Adjusters on bottom of fork legs are 5th click out from fully screwed in
Hope that helps  |
v12al
Joined: 18 May 2008 Posts: 74 Location: Wirral, Merseyside
Posted: Sun May 18, 2008 12:57 am Post subject: |
Hi all... I'm new to this forum.
Just found this thread very interesting... Now I wonder if anyone knows the standard settings for the SB6 (1994 model)... thanks in advance. |
Posted: Sun May 18, 2008 8:33 am Post subject: |
Being as the chassis and engine are pretty much the same, so are the forks and shock, I reckon that the SB6R settings would be a reasonable place to start from  |
Kojay
Posted: Sun May 18, 2008 10:55 am Post subject: |
| Thanks for the info oily .... just need to get ma butt into the garage and get it dialed back to standard and then make the adjustments to suit me. |
Kojay
Posted: Sat May 24, 2008 10:06 pm Post subject: |
Oil n filter changed, new sticky tyres fitted, suspension now sorted ... cheers oily ... TT here I go!!  |
Posted: Sun May 25, 2008 12:14 pm Post subject: |
No problem, anything else I can help with, just shout  |
