Posted: Tue Sep 20, 2011 7:36 pm Post subject: chain roller |
Im trying to find a replacement roller for the rear engine mount frame to stop the bottom run of the chain rubbing it. Its a plastic roller, 30mm internal diameter. Does any one know where to get one, or what bike it is from??
cheers |
Posted: Tue Sep 20, 2011 9:08 pm Post subject: |
Seeing as its a big single rotax engine Nige. more akin to off road bikes, that would be your best bet to start looking, either at motorcycle specs.ze and look at pictures, KTM etc. In my fresher distant past I did enduros and all bikes had the rollers you are talking about due to the slackness required in the chain due to the excessive movement needed of the rear swing arm, just like your BB1, everyone I see has a very slack chain, presumably tightening up when you sit on the bike, DB2 chain check is done the same way. Motocross specialist are your best bet
Chain rollers, lots of em, apologies didn't look through all 645 items on ebay for exact 30mm one, some at 32mm, and larger, perhaps sleeve one down?
http://www.ebay.co.uk/sch/Motorcycle-Parts-Accessories-/14780/i.html?_nkw=chain+roller&_catref=1&_fln=1&_trksid=p3286.c0.m282 |
Posted: Tue Sep 20, 2011 9:15 pm Post subject: |
Do I read you right with the "internal diameter 30mm" Nige? Thats normally the size of the outer diameter of the wheel, picture please |
Posted: Wed Sep 21, 2011 8:31 am Post subject: |
here we are, the engine mount it rolls around is 30mm, this is 32mm id and 40mm od - well whats left of the outside! I've no idea whether the original had a flat surface or was cut to fit the rollers of the chain? I'll have a look on ebay first Niges coffee house always open
Posted: Wed Sep 21, 2011 8:42 am Post subject: |
Jeeso Nige, no wonder you are looking for a new one, before the chain saws the rest of the bike in half.
Looking at one of the others on the Forum I assume its the top roller in the picture below?
Normally the roller's come with a bearing that you bolt through to help it spin, and they may well have outer guides on the edges to keep the chain central, but the rest of the surface would have been flat, a long long time ago.
Happy shopping, other than contacting other BB1 owners directly from the Forum. I could also search out other BB1 owners from the Oldie Bimota Enthusiasts club if you wish as I still have their contacts |
Posted: Wed Sep 21, 2011 9:03 am Post subject: |
No internal bearing!!!
Good old Bimota design dept
If you knew the original shape you could get one turned up
This could be a good time to improve on Bimota design |
Posted: Wed Sep 21, 2011 9:09 am Post subject: |
yes its a gud un! I suspect it is raised on the outer edges and flat in the middle. Nope no bearing -looks like a bit of plastic pipe for a washing machine - perhaps zanussi??? If anyone has a picci of one in better nick or from a parts manual so I can make one much appreciated. |
Posted: Wed Sep 21, 2011 10:28 am Post subject: |
I've got to pop out a lunchtime and pass by the BMW motorcycle dealer in Manchester, so will drop by and view there F650 funduro and other type bikes to see what they use. You never know, engine from them, perhaps Bimota used their rollers also. Like the back light unit on YB11, DB4 plus others, exact same unit still used by BMW on their bikes |
Posted: Wed Sep 21, 2011 2:35 pm Post subject: Found it!!!! |
Here you are Nige, 40mm OD, 30mm ID, nylon pipe under 3 squid for 10 centimetres of it, should keep you going for a lifetime
http:// www. metals4u. co. uk/ detail.asp?cat_id=62&prd_id=2016
EDIT - Url deliberately corrupted by me (admin) at request of the the web bod of the company. Google were pushing them down the rankings due to "detected unnatural links" |
Posted: Thu Sep 22, 2011 9:11 am Post subject: |
thats great -even better as they are not far from me - mmm can feel the pockets draining as we speak |
Posted: Mon Sep 26, 2011 10:06 am Post subject: |
well shiny new roller made and fitted. The problem looks like its a result of fitting a much larger engine sprocket to make the chain clear the swinging arm on the top chain run. This brings the bottom chain into contact with the engine mounting bracket and thus the need for a roller to protect the bracket. I'll see how my home made one lasts the distance! |
Posted: Mon Sep 26, 2011 11:13 am Post subject: |
Did you end up going to that plastics place near you? How much was your fix in the end, and were they obliging in cutting a piece to size for you? Interested in their service as they offer polishing done on site, kits for sale etc, did they seem like a good set of lads? |
Posted: Mon Sep 26, 2011 11:48 am Post subject: |
yes I bought a 100mm long piece -it was ready the following morning. The guys seemed knowledgeable and helpful when I picked it up. It cost me £2.87!! |
Posted: Mon Sep 26, 2011 1:41 pm Post subject: |
Sounds like a good reult, and enough length left over for a couple of spare parts, should stuck them on ebay for a tenner a piece, usual commission my way of course. Hoping to bank enough commission for a sit on your v-due one day, and if I'm really really good...... |
