Sb8r - cooling fans not starting
dbtx
PostPosted: Sat Sep 26, 2026 2:37 pm    Post subject: Sb8r - cooling fans not starting Reply with quote
Hi everyone
Doing a test after filling the bike with new coolant and I notice the cooling fans do not start even when the bike reaches 103 degrees Celsius
Looked at the fuses both are ok
Bypassed the sensor located on the top right radiator and the dash will display “HI” which seems logical but the fans will not start either
What temperature are the fans supposed to run ?
Wondering if anyone has had a similar issue and solved it ?
Thanks
