Furano brakes
nick3584
PostPosted: Thu May 19, 2022 12:47 pm    Post subject: Furano brakes Reply with quote
Does anyone know where I can get rear caliper seals for a Furano???
Nick Barrow
Andrew034
PostPosted: Sat Jun 04, 2022 12:04 am    Post subject: Reply with quote
I don't know what the brand rear calliper is however:
The Furano uses Brembo front brakes (that are the same as Ducati 888SP models of the era) and therefore the rear is likely a Brembo too.
Since the bike mechanicals are based on a Yamaha FZR1000 it is also possible the rear is.a Yamaha unit. And it might be something else all together.
Notwithstanding, brake seals and pistons are relatively interchangeable and come in standard sizes. So a rebuild kit for the correct size pistons will probably work just make sure the cross section of the replacement seals match the section of the original and if your replacing pistons they are the same length to.
I'll look at my Furano if you need some more advice.
Andrew...
Anders
PostPosted: Tue Jun 07, 2022 7:13 am    Post subject: Reply with quote
This seems to fit:
https://www.sd-tec.de/en/brake-caliper-repair-kit-05/item-1-20279910.html
Anders
PostPosted: Tue Jun 07, 2022 8:56 am    Post subject: Furano rear calliper Reply with quote
Two different rear callipers in use at that time. Look the same from the outside, but one has a dust seal that sits over the piston (as in the previous post) and one has a dust seal that sits in the cylinder. You need to take the calliper off and remove the pads to identify which one you’ve got.
