delirio1100
Posted: Mon Nov 30, 2020 10:04 am Post subject: |
Autotune for PC V is an additional module where a sensor inside the header is measuring and adjusting the air/fuel mixture on the fly.
I don't know these units, but they look like Powercommander clones.
I will set up a XP computer (again) hopefully this week as a last try to get communication. |
Quackers
Posted: Mon Nov 30, 2020 4:15 pm Post subject: |
| Ta re the Autotune info. Am awaiting the outcome of your next punch-up with XP with interest. |
delirio1100
Posted: Thu Dec 17, 2020 5:24 pm Post subject: |
Again no luck with XP, as soon as the communication should take place the Bimota software hung up.
I am not sure which com port that software is using, I tried 1 to 5, but anyway it should configure itself, because the official instruction did not tell anything.
The USB/RS232 cable is working, I checked it with terminal loopback.
Drives me mad........ |
Quackers
Posted: Fri Dec 18, 2020 8:44 pm Post subject: |
Del1100
Thanks for that, Hans. Since there is no-one who has recently been able to communicate with a Pegaso ECU using the Bimota software via XP then I知 inclined to consider, for the sanity of us all, that this route is a dead end.......
I知 still pursuing, albeit more slowly since it痴 winter here (and my DB6 is in pieces for some fettling ready for spring), the leads with the two Dyno companies. I致e had no luck, unsurprisingly, with sourcing a spare Pegaso ECU to date (in order to see what the chip is) so I致e just asked Bimota directly (should have done this before, of course) & hopefully they値l be able to answer - or maybe someone else on the Forum knows and is willing to share. If this takes too long, or is fruitless, then I値l either try one of the PowerCommander clones that were listed a few messages ago (Thu Nov 26, 2020 6:23 pm) or look for a secondhand PC. Either way I値l be guided by the Dyno companies.
If that all turns brown then there痴 the Ignitech type route, but I知 nowhere near that yet!
Will let you know as info comes in. |
delirio1100
Posted: Tue Jan 19, 2021 3:04 pm Post subject: |
There is one in Germany for sale but i pass on that one though.
Pegaso ECU f�r 1000ccm 1.122,00 � |
Quackers
Posted: Sat Jan 23, 2021 5:23 pm Post subject: |
Del,
Thanx for that. I saw it too but, like you, chose not to buy.
The Bimota factory have just got back to me. They have no information available for the Pegaso ECU, although they did give me a contact in the Pegaso company itself so we'll see if that leads anywhere. Let's hope so! |
Quackers
Posted: Thu Jun 24, 2021 8:34 am Post subject: |
delirio1100,
You have pm. I could do with some help to get the Pegaso factory to answer some questions about the ECU. |
delirio1100
Quackers
Posted: Mon Oct 11, 2021 8:50 am Post subject: |
Thanks Hans.
How are you getting on with the replacement ECU work? |
delirio1100
delirio1100
Posted: Fri Jan 07, 2022 6:17 pm Post subject: |
I had my ECU checked and they say it壮 OK.
I thought I could skip the connecting issue�. |
Quackers
Posted: Sat Feb 12, 2022 10:03 am Post subject: |
That's good news Hans, in a way . Did they say they could remap the ECU as well? |
delirio1100
Posted: Mon Feb 14, 2022 2:52 pm Post subject: |
No, they couldn't do that. It is still one of the biggist secrets why there is no
solution to this connecting issue and no one on the WWW is able to help. |
Quackers
Posted: Mon Feb 21, 2022 1:27 pm Post subject: |
Yes, irritating on both counts. What are you thinking of doing next?
I still haven't completely given up on communicating with the ECU although am in the process of looking around for a PC III now to cover both bases.
Developing a new (or starting with a generic) ECU, along with a probable rewire, ain't my preferred course of action at this point . |
delirio1100
Posted: Tue Feb 22, 2022 7:17 pm Post subject: |
Not sure, I still think it痴 something stupid. I鼠l put everything back together and see, maybe that check has done something (master reset?!) and it will behave like normal  |
