YB8 / DB4 ally fuel door
PostPosted: Mon Sep 07, 2020 1:43 am    Post subject: YB8 / DB4 ally fuel door Reply with quote
Hi guys,
Does anybody have a YB8 and a DB4? I'm just trying to confirm that the ally fuel doors are the same. Bimota lists them as having different part numbers but they 'look' the same
PostPosted: Mon Sep 07, 2020 1:59 am    Post subject: Reply with quote
Or... if somebody with a YB8 could measure theirs and I can compare it to my DB4 Smile
PostPosted: Mon Sep 07, 2020 8:31 pm    Post subject: YB8 fuel filler Reply with quote
The whole fitting is about 125mm in diameter Brian and the door about 105mm.
PostPosted: Tue Sep 08, 2020 1:07 am    Post subject: Re: YB8 fuel filler Reply with quote
Awesome Jonny, thanks for that
PostPosted: Tue Sep 08, 2020 9:15 am    Post subject: Reply with quote
Are you on about the "false" fuel cap as fitted to DB2/DB4 and a few others......key operated and Voila...theres a plastic tank beneath with a plastic screw on/off cap?
THere is "one thing" you have to watch.....DB2 and DB4 differ in the orientation of the hinge and location of the lock and bimota "b" logo.....so.what you say.....Flip the one up on your DB4....the filler cap is milled out on the underside with a big circular recess.....to allow the plastic proper petrol cap to actually protrude into it when its closed....dont screw the cap on proper and it catches......Yes...you can flip the filler cap around 180 degrees....but its whats under the filler cap recess wise that could make the world of diffference....so...next question is....is the YB filler cap orientated the same way...and is it milled out underneath to accommodate the actual petrol cap??
PostPosted: Tue Sep 08, 2020 9:52 am    Post subject: Reply with quote
YB8 looks identical to DB2.....so take the one off your DB2 and try on DB4.....codes are different though...you may have to fit it 180 degrees around to DB2 though.....as the "b" logo is at the top and hinge bottom with lock as opposed to the other way around (difference between DB2 and Db4)
nichosk
PostPosted: Tue Sep 08, 2020 8:41 pm    Post subject: Reply with quote
Hi Brian, I have a YB8 and a DB4ie and have attached phots below. I can't see any difference other than as 2bims says, the orientation is different. I measured the internal and external diameter and the depth and they are the same. The first photo of both bikes with the flaps open, the next 2 pictures are the YB8 and the final 2 the DB4. I hope that helps. If you need more pictures or other information/measurements, please send me a pm.
PostPosted: Tue Sep 08, 2020 10:42 pm    Post subject: Reply with quote
Thanks 2bims... I hadn’t even noticed that the orientation was different! Rolling Eyes
Reason being.... you and I haven’t been in touch much of late, so I guess your attention to detail is wearing off me.... time for some more lessons sensai
PostPosted: Tue Sep 08, 2020 10:45 pm    Post subject: Reply with quote
Thanks for that nichosk 👍, that does help. Great photos.
I knew there’d be someone out there with both YB8 and DB4 Laughing
PostPosted: Wed Sep 09, 2020 5:09 am    Post subject: Reply with quote
Yeh...apologies Brian...I've been lacking.....Uncle Duties....selling his house and his tat...me selling a house...him living here...me shopping, cooking, cleaning...him eating the food and smoking his pipe....better than Hotel service...they dont let you smoke anything let alone a pipe...but he does follow me around like a lost puppy....
Yup/...orientation differs....sometimes on DB2 or DB4 my ally cap doesnt want to lock....but its simply because the plastic actual cap needs another 1/4 turn to lower it to the level to allow the recess in the ally cap to slot over the top....its probably so precisely milled and engineered that it actually stops the plastic cap from coming undone......I would think though that "one size fits all".....it just means that the orientation may have to be 180 degrees out of sink.....but...buy the wrong one and the "bimota" "b" would be upside down when you sit on the bike....and I know most folk couldnt live with that.....even if you dont actualy have the fibreglass tank/seat unit...surely one day Centrepoint will sell you their one stock unit theyve had forever....and at a sensible price as theres probs only you that wants it
PostPosted: Wed Sep 09, 2020 5:11 am    Post subject: Reply with quote
Theres always someone that has a certain mix of Bimotas.....and nice folk on here that help out.....Just noticed youre listing 12 bikes Brian...I feel inadequate....just the 10 with another coming.....2 BSA's now listed? Have I missed one?
PostPosted: Wed Sep 09, 2020 12:05 pm    Post subject: Reply with quote
Apparently they (Centrepoint) don’t need to sell it that bad. I’ll have to settle for a reproduction seat unit from Greece I think.
PostPosted: Wed Sep 09, 2020 12:09 pm    Post subject: Reply with quote
You’re slipping 2bims, my signature has been the same for over a year I recon 😉
PostPosted: Wed Sep 09, 2020 12:38 pm    Post subject: Reply with quote
Getting old brian.....as each new little piece of bimota knowledge enters....a couple of non bimota memories are deleted...hard drive full....apparently capacity can't be increased or upgraded
