YB8E fork decal position
jimmymach
PostPosted: Wed May 06, 2020 7:26 pm    Post subject: YB8E fork decal position Reply with quote
Reaching the end of my lockdown YB8E rebuild...
When I got the bike the Piaoli stickers on the forks were facing forwards. However, I've seen others that face out. How will it have left the factory? Or is it a case of what they felt like on the day?
Thanks
Jim
PostPosted: Thu May 07, 2020 12:48 am    Post subject: Reply with quote
I don’t have a YB, but the Paioli forks o my DB4 have the stickers on the side. There’s a raised circular outline cast on the fork bottom for the sticker to sit in. Not sure if the YB’s are the same?
PostPosted: Thu May 07, 2020 12:50 am    Post subject: Reply with quote
Have you been able to buy these Paioli stickers anywhere? I searched for them at one stage but couldn’t find them. I’m missing one of them
jimmymach
PostPosted: Thu May 07, 2020 10:27 pm    Post subject: Reply with quote
I found these...
https://www.ebay.co.uk/itm/PEGATINA-PAIOLI-MOTORCYCLES-SUSPENSIONS-DECAL-VINYL-STICKER-AUTOCOLLANT/263234216903?ssPageName=STRK%3AMEBIDX%3AIT&var=562230012072&_trksid=p2057872.m2749.l2649
I don't think they're quite correct so I'm not sure if will put them on.
My YB has the 'b' casting but not the little circle for the icon. The stickers were at the top of the fork lower, just below the dust seal.
PostPosted: Fri May 08, 2020 8:02 am    Post subject: Reply with quote
I'll check a couple of mine later...….but I know the ones you mean....at the top of the fork lower leg where the dust seals are......I think....I had ones on the outer and inner face....as opposed to front and back....But...its Italy....they could be anywhere....good spot on the Paioli sticker though...NEver seen those before....
PostPosted: Fri May 08, 2020 8:03 am    Post subject: Reply with quote
Dont you have a spare now that you've got your DB2 fork legs that you snagged?
PostPosted: Fri May 08, 2020 8:39 am    Post subject: Reply with quote
DB2 doesn’t have the little round raised plastic Paioli stickers.
Although I now have 2 x DB4’s and each bike has one sticker and one missing Crying or Very sad. So I’ll probably transplant one so that my good DB4 has two and the track DB4 will have to go without
PostPosted: Fri May 08, 2020 3:12 pm    Post subject: Reply with quote
Dont know if these are the same dims as per the DB4 forks but look very similar.
can be found here
https://en.50factory.com/pieces-neuves/41014-logo-fourche-paioli-tzr-50-yamaha-et-xpower-mbk-avant-2003.html?search_query=paioli&fast_search=fs
Ive been looking for the gold/black Paioli stickers for my DB2 forks but cant find them either.
PostPosted: Fri May 08, 2020 11:37 pm    Post subject: Reply with quote
I recon that’s very close to the size Ralf, I’ll check mine today. Thanks for the heads up, I’ll order some if they are the right size
PostPosted: Sat May 09, 2020 3:16 am    Post subject: Reply with quote
can be found here
If you peeled them off...you'd find they are clear colourless vinyl...with just black paioli lettering....I have them on the silver fork tops on my db2...a vinyl graphics company shed be able to print some off
PostPosted: Sat May 09, 2020 10:12 am    Post subject: Reply with quote
Yes, that’ll probably be the route I go as can’t find any the right size and font.
hindsight
PostPosted: Sat May 09, 2020 10:56 am    Post subject: Reply with quote
ImageWorks are masters at this sort of thing, I've used them several times.
http://www.bike-stickers.com
PostPosted: Sat May 09, 2020 11:30 pm    Post subject: Reply with quote
These guys in Italy might be worth asking. They have a selection of Bimota decals.
https://www.decalmoto.com/it/bimota/783-yb9-sr.html?search_query=bimota&results=3
Very good pricing. I have just ordered sets for my '95 RGV250, '86 XR250 and '93 Honda RS125.
PostPosted: Tue May 12, 2020 11:21 am    Post subject: Reply with quote
18mm so these are the right size. Cheap at only 2.33€ each..... But 25.90€ for postage to Australia and they won’t do cheaper postage Rolling Eyes
PostPosted: Tue May 12, 2020 9:50 pm    Post subject: Reply with quote
Its 5.50 euros to ship 4 of them to me....as they are in France and give 2 options of postage to Uk….messenger me....I might have a couple just for giggles...as in "buy a couple"
