Fitting an oberon clutch slave cylinder to a DB2
TVRRICH
PostPosted: Tue Jan 14, 2020 9:19 pm    Post subject: Fitting an oberon clutch slave cylinder to a DB2 Reply with quote
I have been thinking about fitting an Oberon clutch slave cylinder to my DB2 as i understand the action is lighter and better ( i have a problem with my left wrist/ hand), i was wondering if anyone else on here has done this. The room between the engine and fairing looks tight, i was wondering if the oberon cylinder sticks out from the engine any further than the standard Ducati one.
PostPosted: Wed Jan 15, 2020 5:43 pm    Post subject: Reply with quote
You should be fine rich yes...they are lighter to pull....but...what master cylinder or levers do you have?...if you are still on the old dog leg and black coffin pot brembo then change for gold series or radial...adjustable levers help also...maybe also change the clutch line....old ones can expand...and wear so less applied pressure in activating the clutch rod....if ordering oberon be sure to spec the engine....some need an extra piece pushing inside the unit to enable the clutch to disengage....upgrade all and fresh fluids....bleed the master off the bike. And its chalk and cheese..
TVRRICH
PostPosted: Wed Jan 15, 2020 8:41 pm    Post subject: Reply with quote
Thanks for the reply 2 Bims, yes its still on the standard master and lever. Will give it a go .
PostPosted: Wed Jan 15, 2020 10:34 pm    Post subject: Reply with quote
Had one fitted to my DB2 SR. No problems!
TVRRICH
PostPosted: Thu Jan 16, 2020 4:05 pm    Post subject: Reply with quote
Thanks Welshlamb, how much did it make the lever action lighter
PostPosted: Thu Jan 16, 2020 10:18 pm    Post subject: Reply with quote
Hard to say as to this, but i could certainly feel it lighter so worth it from my point of view . (Also got my slave cyl from Ebay nearly new for only £55!)
TVRRICH
PostPosted: Fri Jan 17, 2020 1:47 pm    Post subject: Reply with quote
Thanks welshlamb, will definitely give it a go
PostPosted: Sun May 03, 2020 1:32 pm    Post subject: Reply with quote
I think the stock slave piston is 26mm and the Oberon slave piston is 29mm, which makes it as lighter pull. I'm planning on fitting the Oberon slave to my DB4
TVRRICH
PostPosted: Sun May 03, 2020 1:37 pm    Post subject: Reply with quote
Hi Brian, i had one fitted in the end, only problem is i havn't had chance to use it since due to the lockdown !!!
PostPosted: Sun May 03, 2020 2:42 pm    Post subject: Reply with quote
Thanks Rich. They look like a nice unit. There's a few different aftermarket slaves out there, but I like the look of the Oberon one. Hopefully you'll (well, all of us) will be able to get out for a ride very soon Wink
PostPosted: Sun May 03, 2020 2:48 pm    Post subject: Reply with quote
What color did you go with Rich?
TVRRICH
PostPosted: Sun May 03, 2020 6:43 pm    Post subject: Reply with quote
Chose the Titanium in the end, looks OK(not that you can really see it behind the fairing) Laughing
PostPosted: Sun May 03, 2020 7:18 pm    Post subject: Reply with quote
I think it'll be just visible on the DB4. I was thinking of going with the gold slave, but not sure if it'll be a bit too 'blingy'. There are some other splashes of gold on the DB4 so it might look alright.
PostPosted: Sun May 03, 2020 8:22 pm    Post subject: Reply with quote
You can also additionally add washers under springs of the clutch. When I bought new push plate (Ducati Performance) the washers were included. In general 2 valve engines can have washer under every spring, 4 valve engines under every other spring. I can measure them if you need...
PostPosted: Sun May 03, 2020 9:34 pm    Post subject: Reply with quote
On the topic of hydraulic clutches, a common mod on FZR engines like in the YB8 is to delete the hydraulic clutch and fit a cable operated clutch, as I have done in my race bike.
Funny how you get some upgrades like the one in this post with a change in slave cylinder size, other upgrades where you go from cable to hydraulic, and other upgrades where you go from hydraulic to cable. What is best? I guess it's just a case of what you prefer.
