Moreno
Posted: Sun Sep 29, 2019 5:07 pm Post subject: |
| I explored very well everything we need to know about starting up bimota, because even I had a little problem .... could you describe your problem well ?? what happens when you press the start button? you can make a small video whats app at the phone number +393488371519 so I can help you better the spark signal receives it from the phase sensor which is mounted on the lower crankshaft |
Moreno
Posted: Sun Sep 29, 2019 5:12 pm Post subject: |
| when you press the start button the electric motor turns ?? but after 1 or 2 laps does it stop? |
Posted: Sun Sep 29, 2019 6:29 pm Post subject: |
Moreno,
No the engine does not turn from the starter button.
But also, even if i push start there is no spark. |
Moreno
Posted: Sun Sep 29, 2019 7:13 pm Post subject: |
| JRH wrote: |
Moreno,
give it a try, when you push the bike it removes the spark plugs from the engine so the engine doesn't stay braked .... to be able to create the spark the phase sensor needs about 1000 revolutions per minute, so you'll have to push the bike very hard to see the sparks I know very well the electric starter system because I had the problem too if you do a by pass on the starter relay, the motre runs but no spark? |
