Album photo community v due
Goto page Previous  1, 2, 3
PostPosted: Sat May 11, 2019 6:58 pm    Post subject: Reply with quote
Be sure to say Hi to Piero from me.....Just say "the Borsalino English" man...and he'll recall..hopefully....a wonderful fellow indeed
Moreno
PostPosted: Sun Jun 02, 2019 8:19 pm    Post subject: Reply with quote
.This is the color of my ngk b9evx candles
High cylinder
Main jet 330
needle k76
Starting jet 60
Minimum jet 120/40
Low cylinder
Main jet 225
needle k76
Starting jet 60
Minimum jet 120/40
The bike seems to go rich in carburation .... air temperature 32 large
But the color of the candle seems just enough to not seize
The candles has 260 km
Weed
PostPosted: Mon Jun 03, 2019 3:58 am    Post subject: Reply with quote
Have you tried using B8 or 9 ES plugs instead of the of what you are using?
Moreno
PostPosted: Mon Jun 03, 2019 6:43 am    Post subject: Reply with quote
yes I tried, but with br9es candles but the combustion is not obtained .... with these b9evx the engine runs more smoothly What color are your candles?
mick
PostPosted: Mon Jun 03, 2019 2:44 pm    Post subject: album photo community due Reply with quote
I use 220 main jets front and rear and ngk BR9ES colour is biscuit brown.
Moreno
PostPosted: Mon Jun 03, 2019 9:59 pm    Post subject: Re: album photo community due Reply with quote
are your candles lighter or darker than mine?
Weed
PostPosted: Tue Jun 04, 2019 2:23 am    Post subject: Reply with quote
I can't recall the colour but they have in in for 3 to 4,000 klm & still ok. The front plug occasionally miss fires on start up but clears ok.
Your plugs look quite oily. What is your fuel/oil ratio? Last time I looked mine was about 50:1
Moreno
PostPosted: Tue Jun 04, 2019 10:01 am    Post subject: Reply with quote
my gas oil ratio is around 40: 1 I kept the bike full of oil because I took a motorcycle ride this week and it was 260 km and I wanted to stay safe .... I increased the main jet by 10 points to keep the bike safe .... the spark plugs were checked after the lap and I thought I had darker wheels because of the oil and the 10 points more than the main jet
mick
PostPosted: Wed Jun 05, 2019 3:35 pm    Post subject: Album photo community due Reply with quote
This is what I have done to the carburettors on my V-due.
1. Turned the throttle stop screws five full revolutions from closed.
2. Turned the air screw out two and a half turns from closed.
3.Lowered needle jet by one notch (need slim socket)
4. Standard main jets 220......Ngk B9ES spark plugs.
The bike now pulls smoothly from tickover (1200/1400 revs) to full throttle
with no roughness, hesitation or hunting.
As yet I have not altered the oil pump but I will soon.
I hope this helps.
PostPosted: Fri Jun 07, 2019 6:35 am    Post subject: Reply with quote
Courtesy of Mick.....he did a plug chop yesterday at 9000rom....and pulled these plugs out
Moreno
PostPosted: Sat Jun 08, 2019 11:18 am    Post subject: Reply with quote
what is a great color for candles !! I envy your color mine is always clear and I can't understand why !! do you have jolly motorcycles?
mick
PostPosted: Sat Jun 08, 2019 12:19 pm    Post subject: album photo community due Reply with quote
I have Jolly motos exhausts.......the carbs are standard dellorto's set up
the way I have stated, it runs perfect.
I think if you put your carbs back to standard and set them the same as mine
you will be very happy. I would also put the original Ngk plugs back in.
Regards mick.
Moreno
PostPosted: Sat Jun 08, 2019 1:27 pm    Post subject: Reply with quote
mick my bike with your 220 setting, etc. it runs in poor petrol configuration .... my bike needs a sprayer bigger than dq258 ..... is your sprayer dq258?
mick
PostPosted: Sat Jun 08, 2019 6:01 pm    Post subject: Album photo community due Reply with quote
I don't know what size the sprayer (needle jet) is. Everything is standard as it came from Piero.
The biggest improvement was to lower the needle that is attached to the
throttle slide by one notch (you will need a long slim 8mm socket)
I will check all jets for future reference as soon as possible.
Mick.
Moreno
PostPosted: Wed Jun 12, 2019 9:36 pm    Post subject: Reply with quote
what are the mufflers? who produces them?
Page 3 of 3
