robin
Posted: Mon Feb 07, 2011 11:26 am Post subject: Wanted - DB3/DB4 frame bung, DB4 front mudguard, rear hugger |
As above. Not bothered on colour, as these will be resprayed (not the bung). Failing an original front mudguard, any ideas on a pattern or universal part that can be made to fit?
thanks
Robin (Location UK) |
robin
Posted: Thu Feb 10, 2011 5:21 pm Post subject: mudguard |
Hi Oily
Yes, I think that will fit - looks same as the DB4. Price is a bit high though.... I just bought a Ducati 750ss early '90s, and it's mudguard looks right, so I'll offer it up. The forks are unusual in that they have no mounts other than the caliper mounts.
Robin |
Posted: Thu Feb 10, 2011 5:32 pm Post subject: |
That type of mudguard, as fitted to the SB6 etc has drilled and taped caliper bolts and the mudgaurd is fitted with M6 bolts screwed into the caliper bolts, if that makes sense.
If you need it, I'll take a picture
As for the price, about the going rate for carbon fibre |
robin
Posted: Wed Feb 16, 2011 5:09 pm Post subject: Got the mudguard |
Hi Oily
I bought that mudguard you spotted - thanks. I hadn't realised it was carbon fibre, so the price wasn't bad. Here's what it looks like fitted. It clears everything, and will work fine, but I think the Mantra calipers are closer to the fork than the DB3 etc, so it doesn't quite sit right.
I don't suppose anyone has some spare caliper adaptors for the DB3, or one I could copy? A project is never finished!
robin
Posted: Mon Feb 21, 2011 8:19 pm Post subject: Caliper Adaptors |
Here's a picture. The calipers are 40mm, but I have a spare pair of 65mm's off an Aprilia RSV if needed.
Are the ones you mentioned right? I don't read German.. |
Posted: Tue Feb 22, 2011 10:14 am Post subject: |
| I had a quick look at the mudguards over the w/e , and for some reason the yb11 mounting arm seems a bit longer than the others. I will compare pictures to my db4 set up when I get home , and let you know over the w/e. If I have time I will also try the db and yb guards on each other. Don't want to tell you one thing and you waste money on the wrong brackets. |
Posted: Mon Feb 28, 2011 1:37 pm Post subject: |
| Had a look at YB/SB and DB. It appears for some reason the mounting arms on the yb are circa 150mm from the hole centres to the front of the cut out for the forks. The DB/SB are around the 110mm mark. If I fit the YB guard to the DB it appears the same, so the different brake mounting plates will make no difference. |
gianni
Posted: Sat Apr 02, 2011 5:51 am Post subject: Re: Wanted - DB3/DB4 frame bung, DB4 front mudguard, rear hu |
| robin wrote: |
thanks
I have a yellow one for Mantra. New. |
robin
Posted: Sun Apr 03, 2011 9:33 pm Post subject: got one of those |
Hi Gianni
Yep, I've got a Mantra one. I wanted a DB3 one, and the carbon one you see in the pictures is what I got - close, but not quite right. Don't like the Mantra bodywork. |
bidalot
Posted: Tue Feb 14, 2012 12:57 pm Post subject: Re: Wanted - DB3/DB4 frame bung, DB4 front mudguard, rear hu |
| gianni wrote: |
| robin wrote: |
thanks
I need a front mudguard for my Mantra. If you still sell your's you can send me a message.
Thanks. |
