swapping engines
Number2
PostPosted: Sat Dec 15, 2018 6:11 pm    Post subject: swapping engines Reply with quote
Has anyone thought about installing a 1098S or 1098R engine in the DB7? How easy would it be?
PostPosted: Sun Dec 16, 2018 10:19 am    Post subject: Reply with quote
Someone on here did swap out the entire fuel injection system from a Duc 1098 onto a bad running DB7....full wiring loom, ECU and clocks.....Engine is the same....the 1198 will also fit as this went into the DB8....
PostPosted: Mon Dec 17, 2018 11:00 am    Post subject: Reply with quote
Can't see why it would cause to many head aches just the wiring and the ecu really.
PostPosted: Mon Dec 17, 2018 11:28 am    Post subject: Reply with quote
Evidently the 1098R engine like from a troy Corser rep is actually the 1198 engine......As vort says...its down to wiring...you will be chopping and changing a lot to stretch to various things in the place that Bimota fitted them as opposed to where Ducati fitted them....I used to think that they used a standard Ducati loom for the more modern bikes...but now think its a purpose made unit
