AinsleyHenderson
Posted: Tue Oct 30, 2018 7:19 am Post subject: DB8 Idle Issue |
Hi All,
I have a 2013 DB8SP. My problem is its idle seems to be too high at approx 1800 rpm. Aside from being irratating and noisy when stationary, espcially during police stops, it also causes the bike to push forward after closing down the throttle.
I have taken it to a Bimota dealer who says it is running at the correct rpms. I have also taken it to another delaer who has tried to link it to the Engine Management System using a Ducati diagnostic terminal. No luck there.
Everyone I have been to, excluding the Bimota tech, agrees the bike is idling too high, but no one seems to know how to adjust it. I also own a Ducati 999R and it idles around 1400 rpm. I know they are different motors but I wouldn't think the Bimoat would need to idle at 1800rpm.
Any suggestions would be welcome. |
arsenic
Posted: Tue Oct 30, 2018 12:01 pm Post subject: |
Did you checked the throttle cable....?
Sometimes problems come from simple things  _________________ DB8 biposto |
Posted: Tue Oct 30, 2018 2:38 pm Post subject: |
Was going to say the same.....check theres sufficient slack in the throttle cable...if theres no adjustment left at the throttle go to the throttle body end....
What "bimota dealer" did you take it to?...you havent filled out your location or country? |
tassie v2
Posted: Wed Nov 14, 2018 2:32 am Post subject: |
| After the above checks , have a look at the air bleed screws on the right hand side of the throttle body.. |
