Posted: Mon Jul 30, 2018 9:43 am Post subject: |
who wrote: |
https://i.imgur.com/3UtGQ1Wh.jpg
Hi Steve can you shoot me a price one these? Cheers. |
Both steering stem caps accounted for now unfortunately.....I know that Rudolf has had them remanufactured....as "one size fits all" on the Bimota range...SB2 thru to SB6/7...DB1-DB4.....KB1-KB3...YB4-YB11.....he's asking 75 euros a pop though
https://www.bimota-parts.de/en/component/virtuemart/db2/lenkkopfrohrmutter-detail.html?Itemid=470 |
Gammaboy
Posted: Mon Jul 30, 2018 11:21 pm Post subject: |
I've got a stem dust cap - comes with a set of SB6 forks/triples though! |
Posted: Tue Jul 31, 2018 7:33 am Post subject: |
"breaking" them down to parts may be an easier way to sell....big heavy forks are expensive to post though, and that holds some folk back from buying |
Posted: Wed Aug 01, 2018 9:09 am Post subject: Clear-out |
Hello 2bims
pm sent. _________________ What, Jonny's gone! |
Posted: Wed Aug 01, 2018 11:48 am Post subject: |
Right back atchya Johnny |
Posted: Wed Aug 01, 2018 12:10 pm Post subject: |
Final parts remaining.....3 shipments gone to the USA....2 to UK...and 5 to Australia so far...so we know where the money/interest in Bimotas is eh??
Adjustable "travel size" (150x20x10mm) pair of eccentric adjusters for all Bimotas with eccentrics on the rear wheel....hand made from billet with SS bolts and lugs...one fixed one adjustable (because Bimota fitted different sized eccentric blocks to different bikes...of course)
Ducati 750/900SS rear view mirrors...also fit Bimota YB10 and others (NOS)
Bimota Vdue Oil tank/Petrol tank securing bolt/cap...Bodywork spacer...51mm steering damper fork bracket....alloy footpeg insert sleeves and alloy locking nut (bimotas with rubber inserts on the pegs)..Brake foot lever to brake rod connecter swivel....
Slight mark on face of Vdue oil tank/petrol tank securing bolt/cap
brembo rear caliper for most Bimotas...and hanger plate
foopeg inner alloy sleeves/bearing roller
gear rod end swivel that locks with the gear rod foot lever
Theres a mudguard to lower fork leg fixing clamp here...just one half...49mm dia
Gear shaft splined end connecter to gear rod - Oil crankcase filler cap in Billet alloy - Billet alloy oil thermister temp gauge sender for oil line banjo fitment
Pro Bolt alloy turned and tapered and grooved gear shaft rod 210mm long
Theres also a 290-300 adjustable carbon Bimota gear shaft rod...orignally only fitted to the SantaMonicas...but they also fit the Bimota Vdue which has a LOng throw on the gearchange
For all those that have already bought...thanks very much...and for those that I have exchanged discussions and said will hold parts whilst measurements/checks are made etc...all your parts are seperate from all of these already.....so Bri...Paul....Lammie....Johnny and Geekay etc
After this weekend...they will be posted up on the Bimota Specific Facebook Pages and anything left after that will be ebay...so..last chance on here before the advertising is opened up outside of this Forum |
PaulDB2
Posted: Wed Aug 01, 2018 12:19 pm Post subject: |
Steve, PM sent. _________________ Bimota DB1, Bimota YB5, Bimota YB6 Exup, Bimota YB9 SR, Ducati NCR Replica, Moto Guzzi 750 S3, Honda CR750 race replica, Seeley-Suzuki TR500 |
Posted: Wed Aug 01, 2018 12:33 pm Post subject: |
And one sent back to you...and I sent you a text before this message and previous post that should have negated both of our efforts |
Posted: Wed Aug 01, 2018 1:57 pm Post subject: |
Hi 2bims.
You decided if you going to sell me the DB6 headlight yet and what the price is? |
Posted: Wed Aug 01, 2018 2:55 pm Post subject: |
vort28 wrote: |
Hi 2bims.
Correct |
Admin Site Admin
Posted: Fri Aug 03, 2018 3:50 pm Post subject: |
2bims wrote: |
who wrote: |
Both steering stem caps accounted for now unfortunately..... |
Oh well, never mind. I am just a bit paranoid about that part!
Thank you
Katy |
bimota_rider
Posted: Fri Aug 03, 2018 4:00 pm Post subject: |
My parts arrived!!!!
I must say: "Well packed, small package and as promised!!!"
Thank You 2Bims!!!
The extra effort and time spent on my project alone is very much appreciated.
(halfway around the world!!!)
Thank you "Good Friend" ....Man, that made me smile!!!
Thank You SOOO Much!!! From Utah, USA
Tom
 _________________ '98 Bimota SB6R #000016 "Sweet 16"
Built 5/97
2014 Suzuki Hayabusa
2001 BMW R1100S
Posted: Fri Aug 03, 2018 4:07 pm Post subject: |
Admin wrote: |
2bims wrote: |
who wrote: |
Thank you
Katy |
You would have been top of the list....but I've tried to identify who actually "needs" the parts...and yup...need and want have a fine line dividing them for some....and then theres total overlap with others.....Laminator has a "need" as his is cracked....Paul....just shares your paranoia as he had a bike with a cracked one....and 2 others he think may crack....they are still available from Rudolf...so....theres a source IF the untoward should happen...….. |
Posted: Fri Aug 03, 2018 4:14 pm Post subject: |
bimota_rider wrote: |
Its been said before about me....Glad they got there all in one piece...did "we" manage to avoid the dreaded Tax/Import duties??? |
bimota_rider
Posted: Sat Aug 04, 2018 3:39 pm Post subject: |
Why Yes, we did!!!
Don't need no stinkin' Gub-mint.....  _________________ '98 Bimota SB6R #000016 "Sweet 16"
Built 5/97
2001 BMW R1100S
