micic
Posted: Sat Mar 03, 2018 1:02 am Post subject: YB7 - How do you remove the front fairing |
Bought a non running YB7, trying to go through it and see if I can get her running but I am struggling with removing the front fairing. I have removed all fasteners on top (4 bolts) and the front triangular piece that is under the radiator and split the bottom of the fairing, but I can't see how to pull the fairing off. I am not comfortable with exerting a lot of force on the fairing but it doesn't seem that it will clear the forks/wheel to be pulled forward and it doesn't seem it will clear the engine and handlebars to be pulled up.
It is free and it moves but I can't figure out how to remove it short of removing the front wheel but I have no idea how to support the bike if I remove the front wheel other than hanging it by the triple clamp.
Help would be appreciated! _________________ Mel M |
Posted: Sat Mar 03, 2018 6:50 am Post subject: |
Teehee Teehee....welcome to the world of Bimota ownership and one piece "calm shell" fairings....and the reason why they mostly have gel cracks in the lacquer coat......You are right in your assumptions...it has to be prised open and dragged forward and past the front wheel
Most of up lay a spare piece of carpet or old rug on the floor...and a splinter of wood....Bike is pushed forward onto rug and front wheel on the splinter to raise it slightly off the ground...then put the rear wheel up in the air using a paddock stand though the rear spindle if you can...using a piece of steel rod if you don't have the original bimota packing crate stand.....then...find friend if its your first time....and prise open the fairing at the bottom where it splits and guide forward and under the front wheel....piece of wood narrower than the front tyre....carpet there to stop the belly pan scratching on the ground.
Some folk winch the front end up from the yokes using an overhead beam in their garage...I've used heavy duty step ladders in the past positioned over the bike and winched the yokes up from the ladder rungs perpendicular to the tank/engine....You do have to be kind of brutal,....but the fairing is fibreglass so wont snap like if it was plastic |
Posted: Sat Mar 03, 2018 6:51 am Post subject: |
Oh...disconnect indicators at front of course |
Posted: Sat Mar 03, 2018 6:52 am Post subject: |
I'm not "so familiar" with YB7...on my DB2 I can remove fairing with the screen inplace...even though when dropping down it sort of touches the clocks...I like to keep the screen inplace so that it keeps the strength/integrity around the fairing in that area....if the space is tight...maybe remove the screen |
![](images/avatars/21144074044f32e652d46bc.jpg)
Posted: Sat Mar 03, 2018 10:40 am Post subject: |
Dynamite ? _________________ Don't read everything you believe |
micic
Posted: Mon Mar 05, 2018 5:46 am Post subject: |
That helps, I like the idea of the small piece of wood lifting the front wheel. I was thinking about removing the front wheel and supporting the bike from the upper triple but my garage is dry walled and I don't have exposed beams and would require effort, I also thought about borrowing an engine hoist and using that. Thanks for your reply. _________________ Mel M |
Posted: Tue Mar 06, 2018 7:29 pm Post subject: |
Abba used to make a "front lift". It's a hockey stick shape and fits under the exhaust pipes to lift the front wheel - I use one on my SB6. They've replaced them with the Front Lift Arm whick goes onto the superbike stand
https://abbastands.co.uk/product-detail.asp?pid=42 _________________ Don't read everything you believe |
![](images/avatars/24659084853aa6cf435102.jpg)
Posted: Sat Mar 10, 2018 11:06 am Post subject: |
Evilchicken0 wrote: |
Dynamite ? |
Chainsaw works well?
Put the front wheel up onto a narrow block.
A Mate a few beers and it is off. |
