Mike Jennings
Posted: Sat May 27, 2017 12:43 pm Post subject: SB3 Silver |
Hello Folks,
I'm looking for a paint match for the silver used on the Bimota SB3. Any help appreciated,
Cheers, MikeJ |
Ed Light
Posted: Thu Jun 01, 2017 4:13 pm Post subject: |
Hi Mike
I dont know the paint code for an SB3, but, and this is depending on where you are in the UK, down here in somerset I've just used a company called Refinish systems, in Yeovil, to colour match my SB4 pearl white and red. they can match anything, just need a sample to match too. they'll make you a touch up pot, or a proper aerosol ( much better than a shop brought rattle can) or just supply paint so you can get it sprayed. I've used them for years on many bikes, do a good job. if your not around this way I'm sure you would have a local paint supplier with same capabilities. hope this helps! |
Mike Jennings
Posted: Tue Jun 27, 2017 7:48 am Post subject: SB3 Silver |
Hello Ed,
thanks for the reply, I managed to find an area of original paint under the bodywork and had it matched by Leonard Brooks in Harlow (thanks Lisa!) and the nearest was Maxi Car C1-91 Silver metallic,
Cheers, MikeJ |
