My New V Due
Ade sym
PostPosted: Wed May 18, 2016 8:18 pm    Post subject: My New V Due Reply with quote
My V Due has been delivered today!
It looks better in the flesh than it did in the photos from Piero.
Took all the protective wrapping off it, turned on the oil, put some fuel in it, ignition on, and it fired up straight away. All sounds as it should and a Great noise with the JL pipes.
Got a nice paddock Stand, tool kit, fobs, literature, and spare set of decals from Piero.
Parked up for the night, but now need to do the Nova and registering process and hopefully get the registration in the next 3/4 weeks and then it can be ridden.
Will post a few pictures soon.
Ade
Matty82
PostPosted: Wed May 18, 2016 9:50 pm    Post subject: Reply with quote
Good lad, look forward to more pics 😄
Lomas pipes? Thought they were jm in the last photo. An fobs, this is new too
She's a cool bike that's for sure
2SMOKE
PostPosted: Wed May 18, 2016 10:43 pm    Post subject: Reply with quote
Presumably its the big white rubberised Bimota key fob....and not the leather ones like these
http://www.ebay.co.uk/itm/131773707320?ssPageName=STRK:MESOX:IT&_trksid=p3984.m1561.l2649
only got 3 left now though.....20gbp delivered for Forum members.... Laughing
Ade sym
PostPosted: Thu May 19, 2016 3:22 pm    Post subject: Reply with quote
Hi and thanks for the reply.
Yes your right they are JM Pipes..
He sent lots of literature as well as fobs.
Bike has been put on the Nova today so will await their reply and then get it UK registered.
Ade
Ade sym
PostPosted: Sun May 29, 2016 7:01 pm    Post subject: Reply with quote
Had the bike out today whilst it has been a little brighter.
Took a few pictures of the bike:
Took a Video of the bike running which I will post later today.
Hope you like the pictures
Ade
Ade sym
Ade
driift
PostPosted: Sun May 29, 2016 7:59 pm    Post subject: Reply with quote
Looks fantastic. Something different.
PostPosted: Mon May 30, 2016 10:51 am    Post subject: Reply with quote
Love the PVM's
and
not bad in black
Trev
mm500
PostPosted: Mon May 30, 2016 9:57 pm    Post subject: Reply with quote
Really nice looking bike, love the black 👍😀
PostPosted: Tue May 31, 2016 10:33 am    Post subject: Reply with quote
VERY NICE.
Sun is shining and a vdue in the drive way !!!! Heaven on earth !! Laughing
Ade sym
PostPosted: Mon Jul 18, 2016 10:25 am    Post subject: Reply with quote
Had an interesting experience over the weekend!
Filled the fuel tank up 4 days a go, went to start it over the weekend and when I did I had about a pint of petrol exit from one of the rear exhausts!
I note there are no fuel taps on these bikes, (that I can find)
Has anyone else fitted one to stop this problem?
Many Thanks
Ade
Ade sym
Many Thanks
Ade
PostPosted: Mon Jul 18, 2016 12:22 pm    Post subject: Reply with quote
Ah yes, few things to remember with a vdue.
Always turn oil and fuel off when left, most have no fuel tap so just pop the quick release connectors under the tank ( don't disconnect fuel QR completely as you will damage o-ring , just press release so they separate slightly and stop flow).
Have you put the extra bolt in crank halves where the tesi frame would bolt through ? (Don't know if it actually does anything but was recommended to me )
Known a few people have fuel issues on the bike when delivered. Sticking floats and blocked jets are common. (Me included)
Check throttle sync and throttle cable routing/seating and operation. First time I gave mine full warp speed , one cylinder dropped afterwards 50 miles from home. Turned out the throttle cable was badly routed and not entering carb straight and hence outer not seated in adjuster on top of carb. Me pulling it tight had moved it about 8mm, putting carb sync way out .
Give the bike a good PDI , also know vdues to come without fork pinch bolts etc .
PostPosted: Mon Jul 18, 2016 9:12 pm    Post subject: Reply with quote
I always switch the oil off, but have never disconnected the fuel pipes.....
The other bike that Vort and I imported, had a fuel tap, but I didn't like the look of it. You must have had a float sticking......
Ade sym
PostPosted: Tue Jul 19, 2016 5:14 pm    Post subject: Reply with quote
If it does have a fuel tap, where will it be situated as I cannot see it at a quick glance?
Many Thanks
Ade
