Mike Jennings
Posted: Sun May 08, 2016 6:55 pm Post subject: SB7 fairing |
Hello,
apart from the colours, what's the difference between the SB6 and SB7 fairings? Does the SB7 fairing have the larger headlamp apertures?
Cheers, MikeJ |
Posted: Sun May 08, 2016 9:03 pm Post subject: |
I think the SB7 is similar to the SB6 Mk1 - the 6 Mk1 has smaller headlights
The later SB6 has larger headlights and a strengthened seat unit and the mudguard is a bit different (slightly smaller opening under the pipes)
Just remember all bimota suff can cross over so make sure as much as possible what it actually is first. _________________ Don't read everything you believe |
