EYREY1
Posted: Thu Apr 28, 2016 5:43 pm Post subject: chain adjusters |
| anyone know where i can get a set for a mantra v due look the same piero says he has none ? |
Posted: Thu Apr 28, 2016 9:03 pm Post subject: |
| Hhmmm.....be careful on the "look the same"...as in DB4, Vdue etc etc...spindle sizes vary from model to model and sometimes within each model.......I'd say try Armin of DRT schneider...he has parts list on his website of what he has per model...or Rudolf of Bimota-parts.de.....Neither speak nor read and write english...but using google translate you can write to them and they seem to understand....use Paolos website to gain the spare parts numbers as that will help....... |
EYREY1
Posted: Sat Apr 30, 2016 12:17 am Post subject: |
| thank you |
Posted: Sat Apr 30, 2016 9:05 am Post subject: |
Armin of DRT schneider is showing stock of 5 no. chain guides...but whether this is chain guide/slide or adjuster is down to interpretation...but if you contact him or check the part number against the spare parts diagrams it would tell you....(Just checked...its actually a chain slider...)
503 362 090 Kettenschleifer auch DB3
502 381 010
502 381 020 are the part numbers you need for left and right as they differ....one being threaded and one not (for the spindle) called in German.... Kettenspanner rechts....for the right side I believe....I dont think Armin has any...as none showing on his German language lists...so it would be back to Rudolf then as previous post..SB6 parts seem to be showing the same also...there was a bloke breaking an SB6 on Ebay.de |
