YB10 oil idiot light doesn't come on
PostPosted: Sun Feb 14, 2016 5:43 pm    Post subject: YB10 oil idiot light doesn't come on Reply with quote
The oil light on the cluster is supposed to go on when the key is in the ON position, which mine doesn't. Not sure if it's the bulb or the sender unit. its very difficult to get to the wiring with the tester without removing the front fairing. Are the idiot lights plugged in into the back of the cluster? What's the best way to access them?
1991 Bimota YB10
2001 MV F4
2004 BMW R11S BCR
PostPosted: Sun Feb 14, 2016 11:14 pm    Post subject: Reply with quote
It might be easier to access the oil pressure switch and test it first?
PostPosted: Sun Feb 14, 2016 11:28 pm    Post subject: Reply with quote
Where is the switch?
1991 Bimota YB10
2001 MV F4
2004 BMW R11S BCR
PostPosted: Mon Feb 15, 2016 4:19 am    Post subject: Reply with quote
I'm not familiar with Yamahas, but it should be just screwed into the engine block somewhere. Maybe down near the oil pump. It will just be a round switch that screws into an oil gallery, usually only has a single wire.
PostPosted: Mon Feb 15, 2016 4:26 am    Post subject: Reply with quote
Thanks Brian. I'll check in with FZR crowd.
1991 Bimota YB10
2001 MV F4
2004 BMW R11S BCR
PostPosted: Mon Feb 15, 2016 4:51 am    Post subject: Reply with quote
1991 Bimota YB10
2001 MV F4
2004 BMW R11S BCR
bimotabob
PostPosted: Sun Feb 21, 2016 7:56 am    Post subject: Reply with quote
The bulb lights in the crank position.
Check the bulb
The level sensor operates so that it has continuity to ground when your level is good and no continuity when it is low.
Depending on your model you will have one of two types of oil light relay, these make the light work in such a way when you disconnect the sensor it should light up the bulb as a fail safe mechanism.
I had a relay fail but the bulb still lit up when cranked, so sounds like a bulb issue for you. The bulb takes its power from the instrument cluster so would be unusual for it to lose the +12V. And the cranking ground comes from the diode/relay block which us fairly reliable.
YB8EI
PostPosted: Sun Feb 21, 2016 8:25 am    Post subject: Reply with quote
What's the easiest way of accessing the bulb? I see the screws on the back of the cluster that apparently hold the retainer for the light panel section. Am I able to remove just the individual plug at the back of the cluster?
1991 Bimota YB10
2001 MV F4
2004 BMW R11S BCR
bimotabob
PostPosted: Tue Mar 01, 2016 10:08 am    Post subject: Reply with quote
It can't be too advanced, bulbs made to be changed. I'm running ZXR400 bulb cluster so can't advise but i'm sure you will work it out, Heck there are much harder maintenance tasks to be done with the Bike. Your gonna struggle with sparkplug replacement! Smile
YB8EI
PostPosted: Tue Mar 01, 2016 3:36 pm    Post subject: Reply with quote
I guess this will be my project for the weekend though the weather is just perfect for riding. Somehow I'm not looking forward to doing s plug job Rolling Eyes
1991 Bimota YB10
2001 MV F4
2004 BMW R11S BCR
PostPosted: Thu Mar 03, 2016 12:35 am    Post subject: Reply with quote
I can't speak for the yb's, but on sb6 it's even a pain in the arse to get oil back in the engine Shocked
PostPosted: Thu Mar 03, 2016 12:36 am    Post subject: Reply with quote
Not to mention bleeding the clutch slave Evil or Very Mad
PostPosted: Thu Mar 03, 2016 12:37 am    Post subject: Reply with quote
Or changing radiator hoses if you're really adventurous Rolling Eyes
