EYREY1
Posted: Mon Sep 14, 2015 2:58 am Post subject: |
ordering con rod kit from guido
going to upgrade both cranks end of next year once ive run it
and got it something like |
Posted: Tue Sep 29, 2015 10:05 am Post subject: |
Just remembered the rod con I used to convert to slotted rods premix set up is a Yamaha YZ250 rod kit
I have the sizes and details if needed
Trev |
EYREY1
Posted: Wed Sep 30, 2015 2:03 am Post subject: |
trev45 wrote: |
Trev |
did you use thrust washers trev ?
or did you get the big end eye ground down ?
what year yz250 ? did you use yz pin and bearing ?
thats all i could find was yz and cr and a few other 250 mx rod kits but none the exact size or they were exact size and no room for thrust washers .?
ive had then rebuilt now but i will strip it end of next year and up grade the rods so i can run on pre mix |
Posted: Wed Sep 30, 2015 4:09 pm Post subject: |
Email me and I will send you some photos
Trev |
EYREY1
Posted: Thu Oct 01, 2015 11:17 pm Post subject: |
sent you an e mail trev |
EYREY1
Posted: Sat Oct 10, 2015 4:15 am Post subject: |
i got it built up trev !
could do wit an inlet manifold if anyone has bought a flashy frp one and will sell there old one ?
Posted: Sat Oct 10, 2015 8:31 am Post subject: |
Opps
The heads and barrels are on the wrong ends
unless you are running it that way with the
Aprillia chassie ?
Trev |
Posted: Sat Oct 10, 2015 8:32 am Post subject: |
Did you check gear box shimming and end floats ?
Trev |
Tesikwak
Joined: 05 Sep 2013 Posts: 62 Location: Adelaide, Australia
Posted: Sat Oct 10, 2015 2:21 pm Post subject: |
Bugger; this is going to be interesting! _________________ If I don't force my opinion onto others; I expect the same from them! |
EYREY1
Posted: Sun Oct 11, 2015 1:22 am Post subject: |
barrels and heads are the same way as the other aprilia has been done
i might change them round
my mate measured the end float on the cranks if thats what you mean ?
EYREY1
Posted: Sun Oct 11, 2015 2:56 am Post subject: |
this one ,gearbox went back in exactly as it came out ?
ive try'd it and it selects all gears and neurtal
.jpg) |
Posted: Sun Oct 11, 2015 10:46 pm Post subject: |
They can go both ways no problem
I have had gearboxes with no end float
and wrong shims fitted too
But if it is a running bike before
it should be OK again you would think ?
Cheers Trev |
Posted: Mon Oct 12, 2015 8:37 am Post subject: |
I like what you are doing! Just tagging the thread, so I can see how you progress.
I've got a 1RK TZ250 frame (parallel twin) that I'm going to pop a RZ250, with banshee 486 cc upgrades into. We all need a bit of two stroke action in our lives... When it comes to these things, two strokes and I'm done.
Are those V-due motors wider than 90 degrees? sure look well spread out, and two cranks by the look of it? Interesting, but porky.
Cheers. |
EYREY1
Posted: Mon Oct 12, 2015 7:03 pm Post subject: |
i think they are 90 deg and yes 2 cranks
both pistons at the top and fire at the same time
like a big bang 2 stroke
this was only about cranks and what i was doing with the engine
full build thread is on the2strokeforum |
