big end bearings sizes and pic of my build
EYREY1
PostPosted: Thu Sep 03, 2015 2:07 am    Post subject: Reply with quote
so if i had slotted rods trev i would not need to run the pump at all and just have it on pre mix ?
what ratio do you run yours at ? 30-1 or 40-1
my mates v dues go through a liter very quickly
as it has feeds to cranks and some others on inlets or carbs
i dont know which ive not looked but i will do now .
but no smoke comes out of it as such that ive noticed
did you cut the slot yourself in your conrods ?
PostPosted: Thu Sep 03, 2015 9:54 am    Post subject: Reply with quote
On two of the race bikes they are just oil in fuel 25 x 1
no oil pump or oil feed lines to crank etc
I have slotted the standed rods and put other con rods as well
Both will work
Guido has some rod kits three different types
Cheers Trev
EYREY1
PostPosted: Fri Sep 04, 2015 1:09 am    Post subject: Reply with quote
THANKS
my crank builder is going to have a look at the rods and maybe he can slot them , i hope so
EYREY1
PostPosted: Thu Sep 10, 2015 1:04 am    Post subject: Reply with quote
Cranks have gone to my crank builder .
im waiting to hear back from him ,
im hoping he gets them tomorrow
EYREY1
PostPosted: Fri Sep 11, 2015 12:17 am    Post subject: Reply with quote
1 crank needs work ! gutted
PostPosted: Fri Sep 11, 2015 12:48 am    Post subject: Reply with quote
Better new always
Trev
EYREY1
PostPosted: Fri Sep 11, 2015 3:46 am    Post subject: Reply with quote
im waiting on prices from guido and piero
and i will go from there ,thats if i dont have a heart attack when i get told the price of a new crank
Weed
PostPosted: Fri Sep 11, 2015 6:44 am    Post subject: Reply with quote
I've always found Piero's prices pretty reasonable, that's if he has one of course
PostPosted: Fri Sep 11, 2015 10:57 am    Post subject: Reply with quote
What is wrong with the crank ?
Trev
EYREY1
PostPosted: Fri Sep 11, 2015 4:56 pm    Post subject: Reply with quote
its the big end bearing bearing pin or con rod or all of them
PostPosted: Fri Sep 11, 2015 10:40 pm    Post subject: Reply with quote
So just a rod kit cool , easy fix then
do them both , it will love you for it
Trev
EYREY1
PostPosted: Fri Sep 11, 2015 11:30 pm    Post subject: Reply with quote
guido says 160 euros for a std rod kit
so im going to order one
save a bit and get some better slotted ones
and put them in when it breaks lol
i can put them in a box with the spare heads ,barrels,pistons ,crank seals,
ive bought to keep the bike running into the future
everyone thinks you can't get spares for these vdues !lol
how wrong they are ,
both piero and guido are fantastic i spent a lot with piero
but didnt find guido until i had full engine
piero has been great and given me a few items like reeds and crank seals , bolts and a few smalls etc
he didnt have to and i would have had to buy them off him .
PostPosted: Sat Sep 12, 2015 7:40 am    Post subject: Reply with quote
Whilst youre checking and keeping spares...I presume you have a clutch pack? Check how many plates with the friction material you have...if you've bought a new one from Piero you may find theres only 5 plates with friction material and not 6 which is what is needed....a couple of packs that came from Pieros supplier recently both had insufficient number in them......... Sad
EYREY1
PostPosted: Sat Sep 12, 2015 4:01 pm    Post subject: Reply with quote
did he sent you the extra plates ?
i got these just after xmas these are going in the bike so i need to get another set
EYREY1
PostPosted: Sat Sep 12, 2015 7:53 pm    Post subject: Reply with quote
Page 2 of 3
