mortsta
Posted: Sat Jul 03, 2010 5:13 am Post subject: SB8R Front Sprocket |
Can anyone tell me if the front sprocket is standard suzuki?
Its got 17teeth and i'm thinking of dropping it down to 16 which, i hoping will help it through the twisty bits a bit better..
any thoughts?
morty
byron bay australia |
Posted: Sat Jul 03, 2010 11:50 am Post subject: |
I'm guessing it would be
Can't see a reason why Bimota would use a different set up  |
Posted: Mon Jul 05, 2010 10:06 am Post subject: |
If you go up on the rear it's easier to change the sproket and you don't stress the chain as much.
That said dropping the front one tooth won't put the chain under any undo pressure. _________________ Don't read everything you believe |
mortsta
Posted: Sun Jul 25, 2010 1:05 pm Post subject: |
its offset??
afam??
morty |
