Posted: Wed May 20, 2015 10:26 am Post subject: SB6R clocks |
Ah!!!! Wrong again - story of my entire life.
However, with one last roll of the dice, I would suggest that €26 for one bulb delivered, is significantly more than the entire clock-set is worth
Pipe up Oily. I believe you have experience here. _________________ What, Jonny's gone! |
sbbimota
Joined: 24 Oct 2013 Posts: 63 Location: santa barbara
Posted: Sun Jul 05, 2015 12:42 am Post subject: hands and bulbs |
so gents...got the clock apart and am able to access the bayonet style bulb...still no luck finding them....any help would be appreciated...if not, I'm going to wire in LED's....but to do that I need to remove the clocks from the circuit board...I know getting the clock hands is a special procedure...any assist would be appreciated.
pete _________________ pete |
Posted: Sun Jul 05, 2015 8:17 am Post subject: |
Can you post a pic of the bulb? _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Sun Jul 05, 2015 10:06 am Post subject: |
As Brian says, some pictures can help. For me it is not clear which clock you mean. _________________ vince
Posted: Sun Jul 05, 2015 12:58 pm Post subject: |
I think there was one bulb that was really small, I found it in a car parts place. _________________ Don't read everything you believe |
sbbimota
Posted: Tue Jul 07, 2015 7:22 pm Post subject: |
Posted: Tue Jul 07, 2015 10:02 pm Post subject: |
Doesn't it come out of the bulb holder ? _________________ Don't read everything you believe |
sbbimota
Posted: Thu Jul 09, 2015 7:47 pm Post subject: |
it can be removed, but no identifying marks on the bulb. _________________ pete |
sbbimota
Posted: Mon Jul 13, 2015 4:52 am Post subject: LED replacement found |
Found the replacement for the bulb...see photo...found on a LED website...superbrightleds.com...bought the 4mm ones..just when you install don't twist all the way as they contact is just about 5 degrees further around then the standard ones...
this solves the problem..i can then reglue my clocks back together and never take apart again until they crap out..but at least i won't be changing any bulbs.
see ya
