DB5r axle wanted
PostPosted: Thu May 07, 2015 6:04 pm    Post subject: DB5r axle wanted Reply with quote
I am looking for a front axle for a DB5R, the one with Ohlïns forks and Oz wheels.
Spike C.
1965 Triumph T100SC
PostPosted: Tue May 12, 2015 5:19 pm    Post subject: Reply with quote
Give me the dimensions and I will check against my Santamonica. Same set up Ohlins/Oz, so probably the same. I might be able to get a SM one.
PostPosted: Mon May 18, 2015 7:40 pm    Post subject: Reply with quote
Thanks Vort! I have not pulled the axle to measure it, but I just discovered that the Bimota part number for the front axles are the same between the SB8K and the DB5R! Very Happy I assume that means that they are the same....
Spike C.
1965 Triumph T100SC
PostPosted: Mon May 18, 2015 11:25 pm    Post subject: Reply with quote
IS THAT PART NUMBER 505 181 150....
A quick check on Bimota Classic parts says they dont have any.... Sad
http://www.bimotaclassicparts.com/index.php?controller=search&orderby=position&orderway=desc&search_query=505181150&submit_search=
PostPosted: Tue May 19, 2015 2:20 am    Post subject: Reply with quote
that's the one! As a cosmetic fix I installed axle sliders that mask the ground down spot.
A machinist friend suggested turning down the end of the axle past the buggered spot, which would bring the end of the axle close to the fork bottom.
For now the sliders do the job and if worst comes to worst they will protect the rather expensive fork bottoms!
Spike C.
1965 Triumph T100SC
PostPosted: Thu May 21, 2015 2:09 pm    Post subject: Reply with quote
I will check after the TT as hopefully my DB5R will have arrived by then, so will check against Santa one.
PostPosted: Tue Jun 16, 2015 6:11 pm    Post subject: Reply with quote
You still after a front axle Spike. Off to Italy Friday and might be able to get a sb8k Santa one.
PostPosted: Tue Jun 16, 2015 6:32 pm    Post subject: Reply with quote
Hi Vort, although I have hidden the damage to mine with a set of sliders I am still in the market for an undamaged one, so yes, if you find one that will work I would love it! They do seem to be rare as frog hair toupees, though!
Spike C.
1965 Triumph T100SC
PostPosted: Tue Jun 16, 2015 6:39 pm    Post subject: Reply with quote
I will ask my man, he got me a rear Santa axle last year , so fingers crossed.
PostPosted: Tue Jun 16, 2015 6:56 pm    Post subject: Reply with quote
Man from Italy says YES. Will confirm tomorrow. What was the Santa part number so I can confirm it ?
PostPosted: Tue Jun 16, 2015 9:37 pm    Post subject: Reply with quote
Santa part number is further up the thread...which is same as Db5R part Number
PostPosted: Thu Jun 18, 2015 10:05 am    Post subject: Reply with quote
Got confirmation from Italy on axle,about €100-125 depending on which one. Not the cheapest . I will collect it tomorrow whilst there and then post it on from UK .
Not sure what UK-USA will be .
I have said yes to this , are you OK with price ?
PostPosted: Thu Jun 18, 2015 5:42 pm    Post subject: Reply with quote
Thanks so much! I was quoted about $250 so that sounds good to me!
Spike C.
1965 Triumph T100SC
PostPosted: Sat Jun 20, 2015 7:43 pm    Post subject: Reply with quote
Collected axle yesterday, , PM address and I will get a postage quote.
PostPosted: Wed Jul 22, 2015 8:06 pm    Post subject: Reply with quote
Spike, sent you a PM
