rudadue
Posted: Thu Jun 04, 2015 5:33 pm Post subject: Photo of front sprocket spline or shaft with measurements |
| Right Bimo's here' the deal can any one post a photo of v-due front sprocket spline in life size or with measurements so as to see compatibility with something else yes yes it's v-due only, but you never know any way thank you to who ever it is posts photo graph for us to investigate properly with a picky to work from regards to all bill |
Posted: Fri Jun 05, 2015 12:28 am Post subject: |
I can do if you like pm me a email address and I can send photos
But you can buy them cheap ?
Trev |
rudadue
Posted: Mon Jun 08, 2015 8:10 pm Post subject: |
| Hi to you all big up to trev45 , it appears 14 splines 22inner 25 mm outer spline heights now ducati has 14 splines 22.5mm 25mm only the offset of the sprocket teeth in relation to the offset After searching aprilia svx sprocket has the same 14splines 22.5mm inner and 25mm outer spline heights, width of the sprocket is 10.9mm, Gas Gas ec300 ,250,200,hp 450 ,pampers 450 width is 12 mm in total so with a bit of packing ie washer on spline bush to get alignment just an idea certain ducati's have 16.5 mm width any way regards bill |
SethG
Posted: Sat Jun 13, 2015 4:13 pm Post subject: |
Posted: Sun Jun 14, 2015 1:14 am Post subject: |
This is a Ducati 748 sprocket:
Posted: Sun Jun 14, 2015 1:17 am Post subject: |
Aprilia SVX550:
rudadue
Posted: Sun Jun 14, 2015 10:49 am Post subject: |
Hi all
Nice one bud ,what would be good if someone can varify ducati aprilia sprocket fits on spline , then it's a case of skimming/shimming to correct alignment i would of thought 0.2mm would not too much play as it is only the spline height . Then finding rethal one as that would lighter than std
Enjoy the rest of the w/end
Regards bill |
