firststrike
Posted: Wed May 26, 2010 9:25 pm Post subject: ECU black box failure |
Brilliant news, called in to see some guys at two wheel engine services today, in Bridgend S. Wales. Spoke to Dene the owner and explained the problem they then came up with the theory that because only 2&3 were'nt firing possibly was'nt the ECU, most likely cause was the rev limiter, they suggested removing the Rev counter and see if it would run on all four. Guess what exactly right, put rev counter back on and back to 2 cylinders. All i need now is a new rev counter. Must give the guys a plug well impressed with the free advice, they have full machining facilities and are soon to install a rolling road. Thinking of installing a digital rev counter any suggestions? _________________ The Red Barron, Bimota YB9Sri, yamaha RD500lc, yamaha RD500 lc YZR replica, Ducati 750ss |
Posted: Wed May 26, 2010 9:43 pm Post subject: |
That is good news, glad you got it sorted
I won't say, I knew it wasent the ECU t |
Posted: Thu May 27, 2010 8:10 pm Post subject: |
Glad you got it sorted out, I wouldn't have known it was the rev counter.
Try a Koso unit http://www.digitalspeedos.co.uk/ _________________ Don't read everything you believe |
Posted: Fri May 28, 2010 7:07 am Post subject: |
good int. Thats what this forum is all about!  _________________ Pomps
firststrike
Posted: Fri May 28, 2010 6:40 pm Post subject: |
Glad it has been sorted, perhaps it is something for everyone to make a mental note on, not always the obvious. Thank you all for the replies. _________________ The Red Barron, Bimota YB9Sri, yamaha RD500lc, yamaha RD500 lc YZR replica, Ducati 750ss |
