851jim
Posted: Wed May 28, 2014 11:07 am Post subject: Torque setting Paioli |
Hi guys, went to torque up the end cap / bolt on the V due front axle which has the single cap bolt quick release cups and the manual states 100nm.
Surely way too high, can anyone else advise? |
Posted: Wed May 28, 2014 11:15 am Post subject: |
Does seem high...especially for a front wheel....but if the book says so?
The later bikes, DB5, DB6 etc have a sticker on the rear swingarm saying to torque the spicdles to 100Nm......which I sort of do...in that my Torque wrench only goes up to 80Nm.....so I set at that...and then get the long arm pry bar out and add an extra tweak...........  |
851jim
Posted: Wed May 28, 2014 12:14 pm Post subject: |
Thanks for that, I've got too use to Ducati's @ 220nm which is why I did not question it but the front end Duc is about the same but the fittings are much more industrial than the Paioli.
Enjoy the TT |
Posted: Wed May 28, 2014 1:20 pm Post subject: |
Sounds like the early SB6 set up, don't have any means of checking my manuals at the moment but would say that light alloy cap will never take that sort of setting.
Maybe one of the SB6 boys will be along soon and tell you what their manual says. |
Posted: Wed May 28, 2014 2:38 pm Post subject: Paioli torque setting |
I think Bimota were wildly optimistic as to what aluminium threads would tolerate. I've torn threads in the past where I've followed their torque recommendation against my better judgement. I use 60NM on the axle through my Paiolis and have never had a problem. Of course the clamp holds the bolt on the axle tight and prevents it from unscrewing anyway. _________________ What, Jonny's gone! |
851jim
Posted: Thu May 29, 2014 7:01 pm Post subject: |
| Thanks mate, I'll try closer to 60 that's the same as the 916 front axle and its into battleship grade aluminium. |
mad mundy
Posted: Sun Jun 01, 2014 10:20 pm Post subject: |
Wow that seems very high to me, look at what the materials are. One is stainless & the other is an alloy. The bolt is a 10 mm thread. Here is a tip, the reason why all spinners are not the same length of handle thickness is for a good reason. Do the bolt up till you "feel it" in your fingers. There are some very good technicians that don't require tension wrenches. _________________ if you aint` slidn` , you aint` ridn` |
Vdue-pt
Joined: 02 Jun 2014 Posts: 108 Location: North Portugal
Posted: Mon Jun 02, 2014 1:42 am Post subject: |
| On the manual states 100NM, and if all is done correctly there is no problem, but if you dont aply grease then you'll have a problem... |
