Posted: Tue Apr 27, 2010 3:32 pm Post subject: SB6 fuel.......... |
.........light sender/switch.
The bit that screws into the bottom of the tank  |
Posted: Tue May 04, 2010 11:12 am Post subject: |
Okley dokely, obviously a very rare part, anyone know of an alternative that can be made to fit? |
Posted: Tue May 04, 2010 11:38 am Post subject: |
Anyone know who made the originals? |
tlracing
Do you have a pic of it and I'll see if I can come up with something  |
Posted: Tue May 04, 2010 11:43 am Post subject: |
Unfortunatly not as mine's been choped off inside and out, filled with resin and used as a plug to fill the hole
Being as it's a flat bottom tank, it was sort of like a float that moved up and down a central shaft, when it was at the bottom of the shaft (empty tank) it earthed and lit up the low fuel light.
I'll see if I can find a picture in the manuals and parts lists  |
tlracing
Posted: Tue May 04, 2010 11:48 am Post subject: |
P/n. 215000778 perhaps? |
Posted: Tue May 04, 2010 11:53 am Post subject: |
Maybe
I havent got a SB6 parts list
Only a SB6R which of course shows a different part number.....
204020007 |
tlracing
Posted: Tue May 04, 2010 11:57 am Post subject: |
I found that from bimota-parts.de, who have a pdf of the SB7 parts list that also cover much of the SB6.
As it is just a switch I will check later for a circuit diag to see what might be useable! |
Posted: Tue May 04, 2010 11:59 am Post subject: |
Your a star, thanks  |
Posted: Tue May 04, 2010 12:04 pm Post subject: |
Yep, just checked, you.ve got the right part number  |
tlracing
Posted: Tue May 04, 2010 1:04 pm Post subject: |
Okay here goes (idea only as I can't find any more info - sorry!)...
...how many wires does it have? I'm assuming if it's a switch then it will just have two. Easily checked by finding the socket on the main harness. If so, and you bridge this, then the light should come on.
If it's just a float-on-a-stick, then something like this might work:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=150267382785
Sure, it's supposed to be an oil level sender, but works the same and there are several more on fleabay that are similar, so might be worth a punt of a fiver Just search for 'oil level sender' in Motorcycle Parts & Accessories and take your pick.
Alternatively it may be a thermistor, in which case Yamaha use a straight sensor that might be workable:
http://cgi.ebay.co.uk/Yamaha-YZF-R6-99-02-5EB-Fuel-Sender-/350336084504 |
Posted: Tue May 04, 2010 2:08 pm Post subject: |
Thanks for that
Definatly a two wire float on a stick. (Switch)
I've been looking at those oil level senders for a while but wanted to exhaust all possibilites of the genuine article first |
tlracing
Posted: Tue May 04, 2010 2:10 pm Post subject: |
You'll probably find the 'genuine article' is actually the same thing  |
