Posted: Fri Mar 07, 2014 1:01 pm Post subject: Rear axle SB6 |
I’m in need of a SB6 rear axle.
If you have one in stock or you know where I can find one please let me know, I will be grateful.. _________________ vince
Hursty
Posted: Sat Mar 08, 2014 6:56 am Post subject: |
What's up Vince
Have you polished it so much it's out of spec?
Or is it just not perfect like the rest of your bike  _________________ Hursty from kiwi land  |
Posted: Sat Mar 08, 2014 11:50 am Post subject: |
| Hursty wrote: |
What's up Vince
Or is it just not perfect like the rest of your bike  |
Hursty, You have a very good judgement.
It’s true, it’s not that the axle is broken or badly damaged.
But my bike didn’t give any problems or things to solve so I was looking for small things or annoying things. And they promise me that when you buy a Bimota you will always be busy with maintenance. So not true …
The story with that axle is: after I adjusted the chain and torqued the axel is was slightly of alignment.
Only seen when is checked with a laser … (I know I know it’s a bit over the top).
And also with installing the axle I found that I need to use much force. From experience it has to go smooth.
So this winter period I take a closer look at all the parts that are involved with chain adjustment and I found that the rear axle is slightly bend and the chrome layer is blistering. That’s why I want a new axle.
And maybe the problem isn’t a new axle … I’m in need for a new Bimota to modified again to satisfied my needs … maybe a DB this time.
Only my wife thinks I’m in need of psychiatric help. she let me not buy a other Bimota.
And what about you, I was hoping to see this winter pictures of your bike in kiwi-land panorama.
What’s wrong, No time to ride your Bim? _________________ vince
Posted: Sat Mar 08, 2014 11:51 am Post subject: |
Thanks, I'm on it. _________________ vince
Posted: Sat Mar 08, 2014 12:33 pm Post subject: |
There is this new one on Ebay....a titanium Corse one...steep at 349 eruos...but was 699 New...I know that this ebay dealer sometimes takes offers..........
http://www.ebay.de/itm/Corse-Vorderachse-Titan-Bimota-SB6-SB7-/370701445687?pt=Motorrad_Kraftradteile&hash=item564f872a37
Oh...if you find a Sb6 rear spindle...may be best to renew your wheel bearings also...if the old spindle was bent then the bearings may have had a hard life in dealing with the wheel not running true......The Cush drive also has a couple of bearings in it...all should have numbers on the outer face and easy enough to locate replacements
Posted: Sat Mar 08, 2014 12:37 pm Post subject: |
You could probably get one made, it could be cheaper and better than an original. _________________ Don't read everything you believe |
Posted: Sun Mar 09, 2014 10:10 am Post subject: |
| 2bims wrote: |
Oh...if you find a Sb6 rear spindle...may be best to renew your wheel bearings also...if the old spindle was bent then the bearings may have had a hard life in dealing with the wheel not running true......The Cush drive also has a couple of bearings in it...all should have numbers on the outer face and easy enough to locate replacements |
Hi Steve,
The axle on EBay is a front axle. And to expensive.
It’s good you mention the bearings, I was in doubt about the bearings.
I had already inspect them and they look fine, but as you say they had a hard life and it’s easy to find new ones and to replace. Better safe than sorry.
Thanks, my doubt is gone.  _________________ vince
Posted: Sun Mar 09, 2014 10:11 am Post subject: |
| Evilchicken0 wrote: |
| You could probably get one made, it could be cheaper and better than an original. |
And made of Titanium.  _________________ vince
Posted: Sun Mar 09, 2014 11:41 am Post subject: |
How about a group buy to see if the cost could come down ? _________________ Don't read everything you believe |
Posted: Mon Mar 10, 2014 4:10 pm Post subject: |
Hi Vince.
I can get you a brand new one for €95 plus postage , not sure what the postage will be as don't know where you are.
If you would like it I need to know ASAP so I can order it. |
Posted: Tue Mar 11, 2014 9:57 am Post subject: |
| vort28 wrote: |
Hi Vince.
You have pm.  _________________ vince
Posted: Tue Apr 22, 2014 10:28 am Post subject: |
New axle installed
Test ride successfully
Thanks to vort28 _________________ vince
Posted: Wed Apr 23, 2014 10:44 am Post subject: |
| Just glad I could help Vince. Got to keep those glorious SB6's running. |
