tee849
Joined: 03 May 2013 Posts: 23 Location: NE Lincolnshire
Posted: Sat Feb 08, 2014 10:15 am Post subject: Sb6 mark 1 or 2 |
What are the main differences, apart from frame bungs, between mark 1 and 2 on the sb6.
Any preferences ?
Duncan |
Mike Jennings
Posted: Sat Feb 08, 2014 8:08 pm Post subject: |
Hello Duncan
the first SB6s had 'raspberry ripple' red and white bodywork and had straight spoked black wheels. The second group had dark gray bodywork and silver Antera wheels which are notoriously heavy. I believe the later bikes also had differences in the fairing around the headlights. The later bikes also had reinforced seat sections on the bodywork and strengthened exhaust pipes. They're all fast and not terrifically comfortable. Apparently the SB6 R is more comfy but I've not tried one. Oh, and the engine has access problems, like the oil filler being directly behind the frame spar (and the battery is behind the headlights). They need a fair bit of warming up and if you fit pod filters you can get flat spots.
Cheers, MikeJ |
tee849
Posted: Sat Feb 08, 2014 10:32 pm Post subject: |
Thanks Mike,
Ive seen sb6 with a scoop near the bottom of the side fairing and others without it. don't know which is which though.
Hope to have one soon
Thanks again
Duncan _________________ Zzr1400 , 916 Senna, SB6 crescent
Never regret. |
Posted: Sat Feb 08, 2014 10:58 pm Post subject: |
The easiest way to tell is by the speedo / tacho, the earlier ones have a GSXR unit the later ones have a split unit similar to honda rc30.
There's an air intake low down on mine it's in front of the down pipes and might be to stop the fairing from gettin to hot. The oilcooler pipes run past them and if you take the fairing off you MUST make sure the foam rubber is between the fairing edge and pipe. The fairing can cut the pipe.
Posted: Sat Feb 08, 2014 11:33 pm Post subject: |
Some differences that i know of -
Different top engine mount meaning later models have 2 frame bungs.
Later models have bigger headlights
Different gauges
Early models had adjustable steering head angle (later ones fixed)
Later ones have larger vents in tail section at mufflers
Early ones had a top fairing brace coming out of the steering stem nut
I've seen different colours in early and late ones but very few carbon colour.
Antera wheels on later models _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Sat Feb 08, 2014 11:34 pm Post subject: |
Where's oily got to?? He's the sb6 expert
oily, oily _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
tee849
Posted: Sun Feb 09, 2014 12:00 am Post subject: |
Thanks Brian. Much appreciated. _________________ Zzr1400 , 916 Senna, SB6 crescent
Never regret. |
tee849
Posted: Sun Feb 09, 2014 12:01 am Post subject: |
Thanks Evil chicken _________________ Zzr1400 , 916 Senna, SB6 crescent
Never regret. |
Posted: Sun Feb 09, 2014 1:39 pm Post subject: |
Some bikes use 3 spoke Machesini wheels. All the later wheels use 320 brembo discs similar to Ducati / Yamaha but they have countersunk bolts
Earlier bikes use a disc with s bigger offset, these discs are harder to find. _________________ Don't read everything you believe |
