Muzza
Joined: 31 Jan 2010 Posts: 31 Location: Darwin, Australia
Posted: Thu Feb 25, 2010 8:46 am Post subject: Frame spacers |
| I noticed in the parts manual for my SB6R, that I should have a pair of spacers that sit between the tail section and the frame where it joins above the footrest hanger. The part numbers are 504970250 R.H Spacer and 504970260 L.H spacer. Any information in regards to this would be greatly appreciated. |
Posted: Thu Feb 25, 2010 11:18 am Post subject: |
Not that it's any help Murry, my parts book show's the same spacers and they'er not fitted to my 6R either.
Has that footrest hanger arrived yet? |
Posted: Thu Feb 25, 2010 8:53 pm Post subject: Frame Spacers |
No sign on mine either. Are we talking about washers, or a pad or what  _________________ What, Jonny's gone! |
Muzza
Posted: Fri Feb 26, 2010 8:56 am Post subject: |
The part in the parts book looks like a pad with holes in it. By the sounds of things they aren't fitted to anyone's bikes.
Yeah Rob, the hanger arrived in the mail today. At first I thought it was the wrong part due to the different shape, but on further inspection I realised that my damaged hanger was bent way out of shape. Thanks for your help with supplying the part. |
Posted: Fri Feb 26, 2010 9:33 am Post subject: |
Glad it's arrived Murry, I was begining to get worried  |
Posted: Fri Feb 26, 2010 9:45 am Post subject: |
Here ya go JBB, items 13 and 14
Posted: Fri Feb 26, 2010 6:30 pm Post subject: Frame Spacers |
Tks Oily. Definitely not swept up anything like that after I've had mine to bits  _________________ What, Jonny's gone! |
jonoft
Posted: Mon Mar 01, 2010 10:21 pm Post subject: |
These spacers were used for the first batch only (about 20 bikes I believe). The other 580 bikes does not have them. Then there is this issue with the brake discs. The first 3 batches of bikes (about 175) came with cast-iron discs, the rest with stainless. No big deal, except...
Bimota did not inform when they changed, but most mechanics can spot the difference between cast-iron and stainless. Besides cast-iron discs have 12 bobbins, stainless only 10. No big deal, except...
The digital instruments of the SB6R reads 4 special bolts fitted to the bobbins of the cast-iron discs, 5 on the stainless ones. No big deal, except...
The instruments are different. No big deal, except...
Bimota stored both versions in the same parts tray so you never knew which version you got before you fitted it. No big deal if you are Italian, but if you are a pedantic perfectionist like me it is a big deal!
Regards
Jon |
