tommo-sb6
Joined: 08 May 2013 Posts: 36 Location: United Kingdom
Posted: Fri May 24, 2013 6:14 pm Post subject: |
hello Evilchicken,
Got the carbs off, no difference in the compression readings, so it looks like engine out is a must now, while its out at least i can get into the crevices and get it nice and clean, I might even but some new hoses and replace all of them, I really hope its no worse than rings or Headgasket as i didnt really want to spend a fortune on her but if it is so be it...thanks again Tommo |
tommo-sb6
Posted: Fri May 24, 2013 10:19 pm Post subject: |
number 2 exhaust port is looking wet and oily so an internal inspection looking ominous |
Posted: Sat May 25, 2013 10:09 am Post subject: |
JE piston kit then  _________________ Don't read everything you believe |
Posted: Fri May 31, 2013 3:30 pm Post subject: |
Hello Tommo,
How's it going ..... problem already found  _________________ vince
tommo-sb6
Posted: Mon Jun 03, 2013 7:42 pm Post subject: |
Hello Vince, Ive thrown a cover over the old girl for the time being, Im undecided exactly what to do, I might rebuild it and run it for a couple of hundred miles to see if it frees things off, If not then completely take it to bits, Ive been busy just lately with the other bikes, I pick a new zx10r tomorrow trading my cbr1000rr fireblade in for it as that was a rubbish bike, Bad gearbox and burning oil real bad, Not bad aye for a 2012 bike with only 560 miles on the clock, Never buy a fireblade mate they are made from scrap...kindest regards Tommo |
Posted: Fri Jun 07, 2013 8:46 am Post subject: |
tommo-sb6 wrote: |
Okay no fireblade than…
It’s no Bimota but I can only speak for my self ….. I like zx10r pics also.
That’s what I should do, ride the Bim for a while. (Stop when it’s getting worse)
Probable you will find more “things” on your sb6.
Than you can fix it at once.
I think most sb6 riders start that way… _________________ vince
Posted: Fri Jun 07, 2013 1:39 pm Post subject: |
All very well saying ride it but if it's the rings it could soure the bores. That could be the difference between honing and a rebore. _________________ Don't read everything you believe |
Posted: Fri Jun 07, 2013 1:45 pm Post subject: |
Evilchicken0 wrote: |
All very well saying ride it but if it's the rings it could soure the bores. That could be the difference between honing and a rebore. |
stop being the prophet of doom.....if it scores the bores, time for a big bore  _________________ SB6 mk1 (project mega light, big bore)
Posted: Fri Jun 07, 2013 1:51 pm Post subject: |
oily wrote: |
stop being the prophet of doom.....if it scores the bores, time for a big bore  |
Of course .... but I'd say if you're going to the trouble of changing the oil it's better to do a big bore while you're at it.  _________________ Don't read everything you believe |
tommo-sb6
Posted: Sat Jun 08, 2013 6:14 pm Post subject: |
well lads, there is plenty of options but big bore sounds good to me, If i have to go down that route it will have to wait for a while as Am bloody skint at the minute lol..bloody bikes have cost me a fortune over these last few months. |
Posted: Sun Jun 09, 2013 7:14 am Post subject: |
You know it makes sense
You need to ride it now so you'll be able to compare the performance when you do finally big bore it ...  _________________ SB6 mk1 (project mega light, big bore)
