SiBag
Posted: Mon May 27, 2013 2:43 pm Post subject: SB6 Gearbox |
Went out for a blast up to the Pondarosa (Llangollen)
1/2 way there the gearbox started playing up.
A quick blast away from a junction, 1st - 2nd - 2nd - 2nd no 3rd.
Then I finally get it into 3rd and 4th no problem.
Then it wont change down out of 4th.
Finally get it down the box, then all seems OK. turn around head home and it all starts over again.
Get home and try the gears by hand. Linkage seems stiff lumpy and doesn't spring back etc.
I'm presuming its the Pawl springs ? Any thoughts?
Engine out job I suspect. AAAAARRRRRRRRSSSSSSSSSS  _________________ Si...
Posted: Mon May 27, 2013 6:23 pm Post subject: |
Take the gear change off and make sure its moving freely. When you put it back note that it has to be "right" or it fouls and is difficult to change gear. _________________ Don't read everything you believe |
SiBag
Posted: Mon May 27, 2013 9:26 pm Post subject: |
Thanks for that Evil,
I'll take a look one evening. Just a bit gutted today and was not in the mood to start pulling bodywork off etc.. _________________ Si...
Hursty
Posted: Mon May 27, 2013 11:38 pm Post subject: |
If its got Ti#s or Wheels its gona give you trouble  _________________ Hursty from kiwi land  |
Posted: Tue May 28, 2013 1:14 pm Post subject: |
| Hursty wrote: |
If its got Ti#s or Wheels its gona give you trouble  |
and Italian  _________________ Don't read everything you believe |
SiBag
Posted: Fri May 31, 2013 12:06 pm Post subject: |
Bugger bugger,
Took the bodywork off last night for a look see.
Looks like the linkage is all ok, gave it a quick strip n clean.
Seamed to go up and down gears ok-ish.
Bike up on stands, fired it up, up the box ok down the box ok. re-checked every thing,
tried up the box again and it didn't want to change 2nd - 3rd. Looks like as it gets hot the problems start.
Think it maybe a little more serious.
Next stage I think will have to be gearbox out.
Ho hum pif n dandy. _________________ Si...
Posted: Fri May 31, 2013 3:32 pm Post subject: |
That’s too bad, just now the weather is clearing up.
Did you check the engine oil for contamination  _________________ vince
Posted: Fri May 31, 2013 6:46 pm Post subject: |
That's a bit shit Si....
Are you sure it's the box and not the clutch ?
Stick the motor in a jiffy bag and post it down here, I'll sort it for you  _________________ SB6 mk1 (project mega light, big bore)
Niels
Joined: 23 Mar 2013 Posts: 24 Location: Groningen, The Netherlands
Posted: Mon Jun 03, 2013 1:05 pm Post subject: |
| Well the gearbox is one of the very less "weaker" parts of the GSXR enigines. I'm afraid you have to open up the engine... |
Bimsb6
Posted: Thu Jun 06, 2013 8:30 pm Post subject: |
| And then drop in a six speed out of a 750 ! |
Posted: Thu Jun 06, 2013 10:22 pm Post subject: |
| Bimsb6 wrote: |
Has anybody done that ?
I was trying to sus the ratios and if 6th would be higher or lower than the standard box _________________ Don't read everything you believe |
SiBag
Posted: Fri Jun 07, 2013 2:36 am Post subject: |
| Evilchicken0 wrote: |
| Bimsb6 wrote: |
I was trying to sus the ratios and if 6th would be higher or lower than the standard box |
I don't think 6th is any taller, I think 1st is taller and then they are closer ratios.
It was discussed on the old OSS (old skool Suzuki) forum a while back.
The general consensus was that it would be possible, BUT the 750 box is weaker. _________________ Si...
Posted: Fri Jun 07, 2013 8:35 am Post subject: |
...Plus all the little bits not mentioned like......the 750 is a cable clutch and the 1100 is hydraulic so you'll have to drill the shaft for a push rod OR convert to cable clutch  _________________ SB6 mk1 (project mega light, big bore)
Posted: Sun Jun 16, 2013 6:49 pm Post subject: |
Hello Si,
What's the progress  _________________ vince
Posted: Sun Jul 28, 2013 8:44 am Post subject: |
C'mon Si, there must be some news by now? _________________ SB6 mk1 (project mega light, big bore)
