Posted: Thu Nov 29, 2012 2:04 pm Post subject: |
You can get them made up for less _________________ Don't read everything you believe |
Posted: Thu Nov 29, 2012 2:25 pm Post subject: |
I know..........I have quotes  _________________ SB6 mk1 (project mega light, big bore)
Posted: Thu Nov 29, 2012 2:58 pm Post subject: |
Ti sidestands would go well for a group buy _________________ Don't read everything you believe |
sb6rdaz
Posted: Thu Nov 29, 2012 4:09 pm Post subject: |
Why go to the expense and hassle of Ti for a side stand, some decent 6082 aluminium would be fine?
I made my own ages ago, that's never been a problem in the above.
Posted: Thu Nov 29, 2012 6:21 pm Post subject: |
so ... we even have a vollenteer _________________ Don't read everything you believe |
sb6rdaz
Posted: Thu Nov 29, 2012 6:56 pm Post subject: |
Could even make them adjustable for length too, so it doesn't fall over when you jack it up at the rear so it turns properly.................................. _________________ It's mine and I'll wash it as fast as I like! |
Posted: Thu Nov 29, 2012 9:08 pm Post subject: |
I'd settle for just being able to put the stand down and walk away without checking it _________________ Don't read everything you believe |
sb6rdaz
Posted: Thu Nov 29, 2012 9:27 pm Post subject: |
I never mentioned anything like that................. _________________ It's mine and I'll wash it as fast as I like! |
Posted: Fri Nov 30, 2012 1:38 pm Post subject: |
Maybe you could work out a price, I think the SB6 needed and extra 35mm over standard - I'm sure could give a figure for a standard tail height _________________ Don't read everything you believe |
sb6rdaz
Posted: Fri Nov 30, 2012 5:09 pm Post subject: |
It comes down to numbers again, if there's a few needed, it's far easier to op the machining into easy stages, the guy who does my aluminium welding too will be far chearer per stand if there is a few to do, as he only has one set up time, which works exactly the same for the machining, only one set up and more parts made makes them more cost effective.
Guess what I'm saying is, lets see what interest there is in them, then I can work a price out to make that number.
Cheers, shout up then guys!
Daz _________________ It's mine and I'll wash it as fast as I like! |
Posted: Fri Nov 30, 2012 5:13 pm Post subject: |
could do with seeing what it is your asking me to decide on
Are they lighter than the original item? _________________ SB6 mk1 (project mega light, big bore)
sb6rdaz
Posted: Fri Nov 30, 2012 5:26 pm Post subject: |
I'll take some pics, but it looks like a regular Bimota stand but in Aluminium, not steel.
And the OE stand is on the heavy end of the spectrum to say the least, which is why I made the aluminium one.
Posted: Fri Nov 30, 2012 5:30 pm Post subject: |
Well now would be a good time for a small mod......make the foot a fraction bigger to stop it sinking into the tarmac
Adjustable would be an excellent idea too
Subject to cost...I'm in. _________________ SB6 mk1 (project mega light, big bore)
Posted: Fri Nov 30, 2012 5:40 pm Post subject: |
me to ... _________________ Pomps
