SiBag
Posted: Wed Oct 24, 2012 6:43 pm Post subject: SB6 Rear wheel fitment |
Hi All,
What is the largest rear wheel than can be fitted to an SB6
Thinking of fitting a 6" rear hoop, but not sure if there is enough room ?
Has any one fitted a rim this wide ?
Cheers, _________________ Si...
Posted: Wed Oct 24, 2012 7:13 pm Post subject: |
Yes...It's ferkin tight but doable  _________________ SB6 mk1 (project mega light, big bore)
sb6rdaz
Posted: Wed Oct 24, 2012 8:09 pm Post subject: |
Mines 6.25", so I guess mine's bigger than yours! Haha!
As you say though, a bit of a squeeze with a 190 on it too. Would have to space the sprockets out to get a 200 in.
Daz _________________ It's mine and I'll wash it as fast as I like! |
Posted: Wed Oct 24, 2012 8:10 pm Post subject: |
Ah ha.......
Yours is a 6R Daz....
Wider swinger than the 6  _________________ SB6 mk1 (project mega light, big bore)
sb6rdaz
Posted: Wed Oct 24, 2012 8:18 pm Post subject: |
It was in an SB6 before too, so it does fit. And had it in my SB6 briefly before it was sold.
Posted: Wed Oct 24, 2012 8:20 pm Post subject: |
Wow, that would be a squeeze  _________________ SB6 mk1 (project mega light, big bore)
sb6rdaz
Posted: Wed Oct 24, 2012 8:49 pm Post subject: |
As they say, whoever 'they' are, a miss is as good as a mile!
Posted: Wed Oct 24, 2012 9:04 pm Post subject: |
I fitted a 6" with a 180 tyre in one of my 6's and had to shave the welds on the inside of the arm to get a fag paper of clearance  _________________ SB6 mk1 (project mega light, big bore)
Posted: Thu Oct 25, 2012 9:45 am Post subject: |
but not all tyres are the same size regardless of what the sidewall states...........  |
Posted: Thu Oct 25, 2012 10:00 am Post subject: |
why bother Si? _________________ Pomps
Posted: Thu Oct 25, 2012 10:01 am Post subject: |
...Exactly  _________________ SB6 mk1 (project mega light, big bore)
sb6rdaz
Posted: Thu Oct 25, 2012 12:17 pm Post subject: |
When I was running the Antera wheels, a 180 worked much better with those than the 190 the bike came with, turned quicker. The 6.25" rear hoop only came about by a fluke, but worked very well indeed with a 190 on it, Supercorsa's usually. It's tight but the reduction in weight is well worth it, think the Antera's have lead cores, bloody heavy they are.
Posted: Fri Oct 26, 2012 1:15 am Post subject: |
Pompey wrote: |
why bother Si? |
Yes you don't need a wider tyre and it will only slow the handling. You could try the higher profile 180/60 _________________ Don't read everything you believe |
Posted: Fri Oct 26, 2012 9:52 am Post subject: |
Definitely dont fit an oversize tyre to the rim Si! _________________ Pomps
SiBag
Posted: Sat Oct 27, 2012 1:12 pm Post subject: |
I was thinking of fitting some lighter Dymag wheels.
There was a set going for a fairish price on evilblag, but it was a 6" rear.
6" rear appear to come up a little more oftan than 5.5" rears.
Thats the only reason I asked. Not looking for a fater back end but just wondering what the options are.
Love the look of the original Antera wheels, just hate the weight lol..  _________________ Si...
