		wallaman
				 Posted: Mon Oct 15, 2012 6:30 pm    Post subject: Helibars for a DB4? |
				Anyone have any recommendations for a good set of Helibars for a DB4?  I'd like to raise the bars an inch or two (as much as possible).  Getting too old for that deep crouch and long reach to the bars.  If anyone has a set they'd like to sell....?
Thanks.
Chuck S. |
		deebee4
				 Posted: Sun Oct 21, 2012 5:19 pm    Post subject: Re: Helibars for a DB4? |
	  | wallaman wrote: |
Thanks.
Chuck S. |
Hi Chuck,
Any 43 mm cilp on will fit to a db4.
But just remember that when you're making them too high, they'll interfere with the fairing. Your desired 2 inches higher might be too much.  And also the switchgear wiring might get too tight, so keep that in mind too.
Long reach to the bars on a db4.....? Ever rode a Ducati 888, 9xx or a RSV Mille? _________________ Track riding on a Bimota: FUN! |
		robin
				 Posted: Sun Oct 21, 2012 5:33 pm    Post subject: raised clipons |
Honda Blackbird bars are plentiful and give a small rise over standard.
Robin |
		wallaman
				 Posted: Tue Oct 23, 2012 12:19 am    Post subject:  |
				Thanks for the replies.  I have been looking for a set of Helibars for 43mm forks for a bit.  New they are quite expensive, so I was hoping to find a good used set.  A set of Blackbird clipons just might do the trick.  I realize the amount that you can raise them is limited, but every little bit would help.  Getting close to sixty and had some back issues/surgery in my past, so, even the reach on the DB4 can be an issue.  Had a couple of Duc's in the past and an Aprilia Mille (now replaced with a Tuono - a proper motorcycle    ).
Thanks.
Chuck S. |
		deebee4
				 Posted: Tue Oct 23, 2012 5:53 am    Post subject:  |
	  | wallaman wrote: |
Thanks.
Chuck S. |
I see. I've got neck issues (herniated disk, could avoid surgery) myself, but can still manage to keep riding the db4 on track. That's because the position is not as fixed as on public roads, you move around a lot more on track. Only mod is a higher screen and foam padding instead of the stock seat. That gives me a more upright position too. And I'm pretty "compact" so I don't feel "cramped" on my db4. It just fits me perfect.
What's your db4's number, Chuck? Mine's # 0059. Is it a tricolore or an i.e.?      _________________ Track riding on a Bimota: FUN! |
		wallaman
				 Posted: Tue Oct 23, 2012 2:47 pm    Post subject:  |
				deebee4,
My serial number ends in 0012.  The bike is a Tri-Colore with the performance kit installed (Flat Slides, Exhaust, Ohlins rear, etc.).  It runs great and is "almost" exactly what I was looking for.  Light, "simple" (air-cooled), handles great, etc.  I just need to get it a bit more comfortable (my herniated discs were in my lower back - since fixed with a scalpel - I now need to be "nice" to my back so it will be nice to me   ).
Thanks.
Chuck S. |
