Posted: Fri Sep 07, 2012 8:41 am Post subject: |
Road tax sorted, bike prepped, first ride today in ever increasing circles out from the work shop! Anyone fancy a run out this weekend give me a holler! _________________ Pomps
Posted: Fri Sep 07, 2012 9:12 am Post subject: |
| oily wrote: |
| Pompey wrote: |
| Its a Mk1 Vince, standard forks that at some stage had the upper tubes done in gold, very nice to... I got the heat foil from ebay, it seemed expensive but I have been told it was a bargain by those who know better? I'll find the link for you, it was easy to use and super strong sticky back. |
Had the forks TiNi  |
The TiNi fork tubes were genuine Bimota parts for 41, 43 and 46mm forks- I've got a pair for the DB2 sitting here. I think they cost 'a lot' new- apart from somebody trying to sell some on ebay last year for 'a lot', these are the only other ones I remember seeing. A rare catch Pompey : ) _________________ Bimota DB2 tricolore, Bimota YB4e.i, Ducati 851 tricolore, Ducati Hailwood Replica, 1968 Gitan Grillo sport, Yamaha GTS1000, Honda Deauville, Honda GB500 Clubman
http://thecrankcase.com |
Posted: Fri Sep 07, 2012 9:59 am Post subject: |
I have to say I do like the look of the mk1. My last one was a mk2 and whilst the differences are subtle I am beginning to prefer the mk1. Gold forks help I guess.  _________________ Pomps
Posted: Fri Sep 07, 2012 10:15 am Post subject: |
lucky, lucky barsteward
I know better, I've still got the tin of gold paint  _________________ SB6 mk1 (project mega light, big bore)
Posted: Fri Sep 07, 2012 10:17 am Post subject: |
you could paint your motorhome gold! _________________ Pomps
Posted: Fri Sep 07, 2012 5:12 pm Post subject: |
here is a shot of the grill I butchered from a fire guard. Works ok and is heat proof, simples...
Swindon-20120907-00120 by pompstar, on Flickr
Posted: Fri Sep 07, 2012 5:20 pm Post subject: |
test ride went really well. Engine smooth and linear. Not as noisy as my last one but it seemed to make it feel smoother and faster so going to leave it well alone. Gear box is positive if not slick although had to adjust the lever, someone had a club foot. Its a shame I cant figure a way to make it race gearing? I nearly came a cropper twice dropping down expecting it to be a higher gear! Anyone ever done a mod?
Handling was slow to turn in then tucking once over.... mmmm not a flat tyre so going to drop the forks thru the yoke 10 mm to sharpen the steering and allow greater compression damping to stop tucks. Will see how that goes tomorrow. Back end seemed fine, and I forgot how comfy the 6 is. After spending more time on my 888's the leg room and reach to bars is positively lounge like on the 6. You can tour on these no probs... now thats an idea! _________________ Pomps
Posted: Sat Sep 08, 2012 5:00 pm Post subject: |
Put a lot of miles on her today fiddling to get a base setting. All done, had to drop forks 15 mm in the end which is exactly the same as my last 6. Only downside is side stand a bit to long now she is fairly well sorted now so confident to take it anywhere, ran the engine hard thru the rev range and no nasty noises,overheating,or being fuel sick all over the road, result. All that's left is a tyre change as they hoops are old and plugged so not worth the risk. Happy days, now on to the db2! _________________ Pomps
Posted: Sat Sep 08, 2012 5:56 pm Post subject: |
| sounds good, actually had a blat on my 6R today also............... |
Posted: Sat Sep 08, 2012 7:13 pm Post subject: |
They are worth the time invested getting the set up a good average. _________________ Pomps
Posted: Sun Sep 09, 2012 6:41 pm Post subject: |
Being a Mk1 it does have an adjustable headstock so next time it's apart.......  _________________ SB6 mk1 (project mega light, big bore)
Posted: Sun Sep 09, 2012 7:11 pm Post subject: |
I thought you adjusted the rake by changing the bearings ? _________________ Don't read everything you believe |
Posted: Sun Sep 09, 2012 7:17 pm Post subject: |
No....on the Mk1 the bearing rollers are barrel shaped and different offset spacers are used for the bearings to change the head stock rake  _________________ SB6 mk1 (project mega light, big bore)
