Posted: Sat Mar 03, 2012 7:27 pm Post subject: mini o/haul |
decided to get the shock o/hauled and potentially the forks also as its stoopid hard and not good to be out of the seat so easily on the type of roads round here (apologies for the improvised "abba" stand )
as always have come across 'proper' italian engineering..............
look away if your shy...
this linkage bolt cant be removed without first removing exhaust!!
and this is even worse?? think they fitted the bolt and then welded the frame spar in place, comedy gold
Desmo_Demon
Posted: Sat Mar 03, 2012 7:35 pm Post subject: Re: mini o/haul |
| stockcar wrote: |
| (apologies for the improvised "abba" stand ) |
That's the same "abba" stand that is currently holding my GSXR up while it's shock is out being rebuilt. My stand is silver and black, though.  _________________ Look for my books...
"If I Wrap It Tight Enough"
akito-man
Posted: Sun Mar 04, 2012 11:39 am Post subject: |
Kwl, theres never an easy way! Thats why these bikes look and usually go so good, like the( real quater strip streetbike) behind!, nice! _________________ wot you got ?...me..well--
Posted: Sun Mar 04, 2012 11:58 am Post subject: |
Don't know about a mini overhaul...............
In Bimota terms, that's just a minor adjustment  _________________ SB6 mk1 (project mega light, big bore)
Posted: Sun Mar 04, 2012 12:46 pm Post subject: |
| will get a full check-over, oil change & linkage grease, fork re-build, etc. as the weeks progress (work permitting) |
Posted: Sun Mar 04, 2012 5:41 pm Post subject: |
Really you should have dropped the engine ... _________________ Don't read everything you believe |
Posted: Sun Mar 04, 2012 6:12 pm Post subject: |
| why?? |
Posted: Sun Mar 04, 2012 10:16 pm Post subject: |
It's a joke
(kind of ) _________________ Don't read everything you believe |
Posted: Mon Mar 05, 2012 5:15 am Post subject: |
mainly because we all had to. Just about every time...  _________________ Pomps
