Bimota junkie
Joined: 10 Apr 2010 Posts: 4 Location: Denver CO, USA
Posted: Sat Jul 16, 2011 1:04 am Post subject: SB6R chain |
| Finally wore out the chain on my SB6R. Can anyone out there tell me what size chain it is? Any ideas on the best chain and sprocket out there, it has been about 20 years since my last chain purchase. Thanks for the help. |
Posted: Sun Jul 17, 2011 2:42 pm Post subject: |
If you clean up one of the side plates the chain pitch is stamped into it. put some white paint on one of the links and then count them.
If the gearing is ok for you then simply count the teeth on the sprokets, the front is GSX-R1100W. The rear might be better to scan and send to the place you order them from althought they'll probably turn out to be the same bolt fitting as the modern Laverda 750 parrallel twin. _________________ Don't read everything you believe |
CBar
v12al
Joined: 18 May 2008 Posts: 74 Location: Wirral, Merseyside
Posted: Thu Sep 15, 2011 11:28 pm Post subject: |
acording to the fitment chart I have here regina do one and its 532/136.2 ZRP Xring or Z ring if any of that makes sence. Thier contact number is 01283 525252.
Hope that is some help. |
