barsrider
Joined: 22 Feb 2011 Posts: 13 Location: istanbul/turkey
Posted: Tue Feb 22, 2011 7:21 pm Post subject: DB5 STANDARD SUSPENSION SETTINGS |
hi everyone...greetings from turkey...
i have bought 2006 db5 mille...but i have a problem...suspension settings are not original and unstable... i have tried to adjust same as my other bike 1098S but still not good...i need to turn back standard settings but i couldn't find owner's manual...Can someone help me to find standard settings or owner's manual?
thanks |
Posted: Wed Feb 23, 2011 10:00 pm Post subject: |
tough call. You are running full ohlins front and rear on that model. It would be an idea to get in touch with ukbimota who is a member of this site to let you know what they are. I would adjust the front and rear sag first thing as the preload is most commonly abused by fiddlers. Then, if failing to get the info quickly its not a bad idea with ohlins to count the available clicks from fully in to fully out and go back to the middle, for compression and damping. Then ride her and see how she feels. Adjust one thing at a time by 4 clicks and see if it improves things. If it feels better adjust by another 4 clicks in the same direction. As soon as it feels like its going wrong again then go back 2 clicks stay there until all four adjustments have been made. Its a very, very crude method but should get you in the ball park and at least safe. Always difficult with high standard suspension to get the sweet spot but it will be worth playing with... Good luck. _________________ Pomps
Posted: Thu Feb 24, 2011 4:16 am Post subject: |
If you go down the center setting route then I would try tightening ( hardening) suspension clicks clockwise...
If you can let me know what the symptoms feel like I may be able to help a bit more. Does it feel vague, wallow , squirm ( front and/ or back )? _________________ Pomps
barsrider
Posted: Mon Feb 28, 2011 8:19 pm Post subject: :) |
hello Duncan...
i am trying your method as you said...i am counting clicks and recording it...but weather is cold and rainy...i couldnt find the time to go track...last time back suspension was hard and wobbling...i am counting clicks and recording it...it will take time this way,not easy ... i have also ducati 1098...i found standard setting's number of clicks from ducati owner's manual and i will try it on bimota...meanwhile how can i reach person who from UKBimota?i really need to know number of clicks...
thanks for your answer... |
Posted: Tue Mar 01, 2011 2:39 am Post subject: |
Go in to "members" section at the top of the page and search for UKbimota. Click on this name and then click on the "pm" (private message). I will do the same to let them know to get in touch with you. _________________ Pomps
barsrider
Posted: Tue Mar 01, 2011 2:27 pm Post subject: thanks! |
you are very kind Duncan thanks alot!!! |
Posted: Wed Mar 02, 2011 9:48 am Post subject: |
No problem, thats what the site is all about, I have more then my share of help from the rest of the members... Graham from UK Bimota should be in touch, he answered straight away, very cool. Good luck... _________________ Pomps
UKbimota
Joined: 19 Feb 2010 Posts: 85 Location: South of England
Posted: Fri Mar 04, 2011 8:43 am Post subject: DB5 Settings |
Hello Barsrider,
If you could send me your address on the PM page or email me I will send you the settings and copy of the DB5 handbook. Its not a problem.
Kind regards
UK Bimota
Merhaba Barsrider,
Bana PM sayfadaki adres gönderebilir ya da ben size ayarları ve bir kopyasını gönderir bana e-posta
dB5 el kitabı. Onun değil bir sorun.
Saygılarımızla
İngiltere Bi _________________ Ciao Italy and we wish Rubes Xaus all the very best in the racing department. |
UKbimota
Posted: Fri Mar 04, 2011 9:53 am Post subject: DB5 Suspension |
Thank you for sending me your address in Turkey.
I will post all the details to you this evening.
Yours sincerely
UK Bimoat
Bana Türkiye'de adresiniz gönderdiğiniz için teşekkür ederiz.
Ben bu akşam size tüm detayları yayınlayacağız.
Saygılarımızla
İngiltere Bimota _________________ Ciao Italy and we wish Rubes Xaus all the very best in the racing department. |
barsrider
Posted: Sat Mar 05, 2011 5:29 pm Post subject: thanks |
I really don't know how to thank...I want to move my house to U.K. because world's most kindest people lives there...If you want to visit my country,it will be pleasure to entertain you...
kindest regards |
