Db2SR, this time: connections on the petrol tank
Ahab
PostPosted: Tue Jul 26, 2022 9:40 pm    Post subject: Db2SR, this time: connections on the petrol tank Reply with quote
Ahoy everyone,
I have a problem with my gas tank. I took out the fuel pump for an inspection. This is how it came out:
I thought, that's no problem, I'll unscrew the cable clamp too.
So I turned the part clockwise as the sticker said. It could be turned, unfortunately it didn't come out...
I have no idea how to solve the problem. What's on the spot in the tank. Is there a sleeve with a thread laminated in?
Help!
Ahab
Ahab
PostPosted: Tue Jul 26, 2022 9:42 pm    Post subject: Reply with quote
from the inside
fish
PostPosted: Fri Jul 29, 2022 5:05 am    Post subject: Reply with quote
Had the same problem with my db2sr . If I remember correctly it is the power wire for fuel pump.I drilled it out put a new wire through and glued it in hasn’t leaked yet.tried to solder a new wire on but no success as I could not get the fitting out of tank . Cheers craig
DB1-DB2SR-DB2EF-DB3-DB4 Db10 YB6-yb7_yb10-2xyb11-SB5,2xSB6-kb3-yb5-MILLE MIKEHAILWOOD HARRIS MAGMAN2-TRIUMPH T140-RG500x2-KAWA Z900-SUZUKI GSX1100-DUCATI 900SS- 750 sport ducati DUCATI F1 750- 851 tri colour-500sl-1996 Trumph datona . Vee two alchemy
View user's profile Send private message Send e-mail Yahoo Messenger
Ahab
PostPosted: Wed Aug 03, 2022 8:58 pm    Post subject: Reply with quote
Yes, it is the power wire.
Thanks for the idea of ??drilling out, but I don't dare to do that at the moment.
Does anyone have such a tank of a DB2SR (maybe as a reserve on the shelf) and could post photos here?
Thanks
Ahab
fish
PostPosted: Thu Aug 04, 2022 6:02 am    Post subject: Reply with quote
Yer I have one but not home for a weeks time
hindsight
PostPosted: Fri Aug 05, 2022 7:58 pm    Post subject: Reply with quote
Hey guys - I added a fuel level sensor to mine a while last year. Some photos in this thread here, if it helps:
http://www.bimotaforum.co.uk/viewtopic.php?t=6628
Regards,
Mike
