Fuel Tank Clear Line Routing
BruBear
PostPosted: Sat Feb 26, 2022 10:01 am    Post subject: Fuel Tank Clear Line Routing Reply with quote
Morning guys, hope your all doing well?
I've been fiddling with my FI and in a fit of madness, when taking off the fuel tank, after disconnecting the fuel line, I pulled too hard and disconnected the clear pipe on the right hand side of the tank.
It hasn't come off the tank itself but somewhere it was attached to. Where should I be looking to route it and reconnect it. For the life of me I can't see where it should go.
Thanks Allan
Weed
PostPosted: Sat Feb 26, 2022 12:44 pm    Post subject: Reply with quote
Possibly will be the drain line from the fuel cap. It sits on the RH side but towards the back of the tank
Weed
PostPosted: Sat Feb 26, 2022 12:45 pm    Post subject: Reply with quote
Possibly will be the drain line from the fuel cap. Ut sits on the RH side but towards the back of the tank
BruBear
PostPosted: Sat Feb 26, 2022 1:06 pm    Post subject: Reply with quote
Thanks, Yip, that's the pipe, it's about a half meter long. Sits at the back of the tank. So as long as I fine a decent rooting it should be fine.
